Page 2 of 2 FirstFirst 12
    Perhaps "starve" is a bit excessive :D
    A 1 Farad capacitor would deliver one Amp for one second, so .00047F is good for about half an Amp for 1 millisecond.
    Your stepper driver should have built in decoupling to handle fast transients. I think maybe you are getting bogged down worrying about things that aren't going to give you problems.
    You can add fuses and fat caps later if you find a need, but I don't think you will.
  2. While what you are proposing CM will work, good electrical working practice is to independently feed high current circuits directly from the power supply to minimise interaction between circuits.
    The reasons are many:
    1/ A good quality power supply is a low impedance which will absorb transients. Daisy-chained circuits potentially allow transients from one driver to impact on another, for example the back-emf from the driver into the PSU when the motor coil is switched. This can push the supply voltage up several 10's of volts and it may be that only the PSU's impedance and back-emf protection is protecting the other drivers.
    2/ Starvation is possible, if for example the connection between motor 2 and 3 isnt as good as that between motor 1 and 2 (the feed being to #1) and motors 1 or 2 are drawing a high current then the voltage across motor three may drop several volts leading to poor torque regulation. However we only really need to consider this possibility where the resistance of the connection is likely to be significant in respect of the current drawn - traction systems for instance where the current is measured in tens or hundreds of amps.
    3/ Step current demands are transients and the shape of the step is determined by the higher frequency components which by their nature travel in the outer skin of the conductor. Long conductors present a much higher impedance to transients and therefore can benefit from localised capacitive reservoirs. Without the right equipment (osclliscope for instance) its impossible to tell whether these are actually needed. One determining factor will be the regulation capability of the power supply... i.e. how the output voltage changes under repetitive step current loads. A 5% regulation is considered poor, 0.1% would be pretty good (thats 2.5v or 0.05v on a 50v supply).
    You say your power supplies are rated at 7A typical, 9A peak and you are running them in parallel. What supplies are they and are they linear or switched mode regulated or unregulated? If unregulated or switched mode you may find extra capacitance at the motor beneficial (but again it can be hard to tell).
    Make sure the wire connecting the supplies together is heavier than the motor wire - best practice is to wire both supplies to a common connector block from where the motor wiring is taken (in high current systems a copper bar (busbar) is even better). Failing this, use 2 or 3 pieces in parallel.
    I would argue that fuses are essential. If they 'go wrong' and are correctly sized then its a sign there is a problem somewhere... better to blow a fuse than fry a driver...
    Incidentally, I just re-read your original post re your 'electrician'... I reckon he was talking out of where the sun don't shine!
    Hey Robin, that quote i did in my last post was just somthing i found on a guys build log website, i wont be caping anything
    Ok thank you, i just wanted to now and understand/learn rather then just be told :).
    They are from MCP, PS407:
    The PS Power supplies are available as 40V and are non regulated switch mode power supply specificaly made for use with our range of stepper and servo drivers.
    Supply Voltage: 180 to 250V AC
    Output Voltage:
    • PS407 - 40V DC at 0A and 38V DC at 7A
    Output Power
    • PS407 - 260W (Continuous)
    I will look at how i would like to go about connecting the supplies together and get back to you with what i propose doing, could i use copper clad board as an option? reson being i'v got some of the green screw terminals you find on the BOB boards i could solder in.
    I couldnt agree more, while the drivers dont cost a fortune, it would be much more inconvenient replacing one of them, then a fuse located on a front panel deisgned with easy access in mind ;).
    I'v just found this as well: http://www.mycncuk.com/pdf/wiring.pdf
    CM
  5. #15
    If the fuse goes pop because the driver has fried, you are going to buy a new driver anyway. They are so cheap they aren't worth repairing.
    If a fuse goes pop for no good reason, the part you are cutting becomes junk PDQ. Then the cutting tool ploughs into a holding clamp, the bed dances a jig and it can get really expensive really quickly.
    You don't want to end up using both hands to stall it while trying to switch it off with your foot :D
  6. #16
    If the fuse gos "pop" then the driver stops as dose the motor as dose the axis in question ?, isnt the fuse there to protect the driver from becoming fried?
  7. Quote Originally Posted by CheekieMonkies View Post
    I think what Robin is implying is that the fuse wont blow as fast as the driver could fry and that's certainly true for certain situations but if you short the motor wiring by dropping a screwdriver on it or the motor overheats and internally shorts a turn the fuse will still probably blow before the driver's MOSFET fails cos of thermal runaway unless it is very tightly spec'd...
  8. Quote Originally Posted by CheekieMonkies View Post
    No problem, happy to help
    I'd be careful of those green things, most of the 0.1"/2.5mm spacing found on BOBs are only 1 or 3A rated. You'd need the bigger 0.2"/5mm spaced versions which are 7 or 10A rated
    What I've done in the past for some high power radio gear is taken a length of brass bar, 8mm x 4mm, drilled the ends 4mm clear to fit the PSU terminals (3.2 or 3.6mm screw lugs) and then drilled/tapped 3mm (or similar sized BA) take off points for ring terminals along the bar (use brass screws)
    CM
    Yes I've seen that diagram before... note its a connection diagram not a wiring layout diagram - it shows what connects to what, not how to do it properly.
  9. #19
    what is the differece between ac and dc amps if any?
    I was told:
    So after comparing a few other sources on the differences between, AC and DC i'm happy that the above is true.
    The reson for my original question regarding amps was because i am currently selecting the correct wire to use as supply lines to each of my driver cards. To futher explain that, i was already aware that diffrent gauges of wire would also draw current and if that is the case i needed to also ask the original question above.
    Hopefully this post will also help somone else in the future, who may be looking for the same answer!
    What i would like to know now is, how do we determine when a wire will start to draw current?
    The reson i'm asking this question is because when i had my out building wired by an electrishion, he told me that you can't use over rated cable because it would draw, build up, demand current itself. So if thats the case really to do the job right i need to make sure that the wire i use to supply each driver, isnt going to do the above.
    Maybe you guys could help me with this, am i going "way overboard" for what my circuit will be doing? or is this a good show of consistency in doing the job right.
    What i'm basically getting at is this, my PSU is currently supplying my circuit with 38VDC @ 14a. Each of my driver cards are rated @ 4.2a (RMS 3A) MAX, so we know that the driver cards combined could require 12.6a (4.2 x 3 = 12.6).
    The wire i have decided to use is rated @ 15a, so 15 - 12.6 = 2.4. So my wire should handle what is being requested in ampage but will the wire pull a little more current from the PSU as its rated @ 15a and a little over what the peak will be, going back to what i said above about wire and the (draw, build up, demand) ?
    Now moving onto fuse's to protect my driver cards, i understand it that fuse selection is done so by adding 25% to the peak rating. So 4.2 + 25% = 5.25, so i would need to use a 5.25a fuse to protect each driver but actually a 5a fuse is the closest i can find so thats what i will be using? and if its true that the wire will (draw, build up, demand) do i need to take this into consideration on my fuse selection.
  1. maximum amps
    By petejw in forum General Electronics
    Last Post: 11-08-2009, 11:40 PM
