Thread: dc motor help
Hi guys picked up a motor of ebay think it came from a golf cart or granny wagon lol
fair size any how connected the motor to a car charger to test it out works fine
24v = 2100 rpm ish not realy shure what the voltage for this motor should be as the specs have come off the sticker
i adjusted the pot on me speed controller right down on max speed which gave me
0-100volts used a meter to mark 24v on the knob
was hopeing to use my mills speed controller to drive this motor but when i connected
the motor it sounded rough cogging and rotating very slow also adjusted the torque setting right down and slowley raised a little no joy any ideas guys
24-10-2010 #2
Is you speed controller AC or DC?
24-10-2010 #3
speed controllers DC
24-10-2010 #4
open the motor to check the bearings and found one the the brush wires had come off the motor has 4 brushes
now at 24v i get 3000 rpm also noticed that the charger is showing the motor drawing 10 amp
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
