Thread: minimum tool & skill set
At work my toolset is VS2005 and the kernel debugger :geek: Apparently these are absolutely rubbish when it comes to woodworking.
So at home I've got a small handheld jigsaw, sander, dremel (did I mention I *love* it??!), hand drill and a few other bits n bobs.
As for non-electricals I have a small try-square, a long metal ruler, a collection of screwdrivers, chisels, hammers and all the other clart you'd expect a part-time-DIYer to have.
I'm lusting after a router table at the moment, but I honestly don't know if I'd ever use it more than a couple of times a year, if that. For a job such as putting together a Rockcliff, do you think nipping down to HSS and renting either a table saw or router table would be worthwhile?
Another thing that I think might get some use would be a drill press. How does the panel rate the stands that you get for your black'n'decker??
I know that tools are only half the equation and I opted out of O level woodwork, so any tips on the 'software' side of things? Sites to visit that'll gen me up on things like making good 90degree corners, etc??
Charlie
Best timing belt and pulleys type for minimum backlash
By paulus.v in forum Belt Drive, Pulleys & TimingReplies: 14Last Post: 10-06-2018, 11:18 AM -
Minimum PC requirements
By manofgresley in forum Computer HardwareReplies: 2Last Post: 26-10-2013, 04:33 PM -
Minimum thread engagement
By JoeHarris in forum Metalwork DiscussionReplies: 3Last Post: 18-08-2013, 12:35 AM -
minimum lead screw size and support bearing sizing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 30-03-2013, 04:51 PM -
Cheapo Leadscrew with minimum accuracy requirement!
By Vikash in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 06-10-2010, 11:17 AM
