  1. #6
    MC,
    I have just been thinking about what you are trying to do and I think that you could do it with a fairly simple design.....
    What I am thinking is that you will only need 3 directions of movement, Rotary (A) to spin the pipe, Linear (X) to move along the pipe and Vertical (Z) to plunge the cutter. You could even do away with the Z axis being controlled by steppers and do it manually seeing as you are only cutting through pipe, just a thought.
    With a max pipe dia of 8" then why not limit the travel on the X axis (along the pipe) to something similar, maybe 10"-12" will do. Moving along the pipe to cut various other holes could be done with a second linear move and clamp system that could be positioned manually anywhere along a 5ft pipe.
    Your design then could consist of a fairly small X axis which could be done with a ballscrew as you will only need a small amount of travel. Same goes for the Z axis (if you go for stepper control), use a manual move and clamp method to get it close to the pipe surface depending on the pipe dia and then you will only have a small distance to go to plunge through the pipe.
    Pipe would be held at one end by a chuck which is controlled by a stepper motor for rotation and by a simple 3 roller type system at the other, 2 at the bottom which again have a manual height adjustment for various dia pipe and one roller at the top to hold it on place.
    Hope that makes sense, trying to dip a hobnob in my tea at the same time as typing this is a bit distracting.
    Have a look at the photo below then read my post again, may make a bit more sense!
Name:	CNC Pipe cutter.png
  1. WANTED: 150mm dia x 15mm wall Ali pipe
    By r0bsk1 in forum Items Wanted
    Last Post: 12-06-2014, 04:19 PM
  2. I need to build a tube profiling machine
    By Paulgy80 in forum Gantry/Router Machines & Building
    Last Post: 13-04-2014, 12:58 PM
  3. 3mtr CNC pipe profiling machine.
    Last Post: 23-08-2013, 08:49 PM
  4. New machine Ideas
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 19-09-2012, 10:18 AM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
