That extra info is good!
For the drilling, you need an A-axis, if you want the material turned automatically. To begin with, as you're only drilling holes on opposite sides, you could always just rely on turning the pipe by hand (machine drills/machines one side, then spin the pipe 180deg and let it do the other side).
However, now that I know the type/size of holes you're doing, a x and y axis is pretty much essential.
For the bigger holes, in order to keep the edges parallel, you either need to use a milling cutter and move the work under the cutter, which requires 3 way movent (up/down, fore/aft, right/left), or to rely on having the correct sized cutter so the pipe remains stationary.
The hardest part I'd say to design, will be some form of clamp/support for the pipe. Rotary table at one end with chuck to control rotation of pipe, then on the moving head, some form of roller/guide assembly on the head to support the pipe at the cutter (probably one either side of the cutter for maximum support).
WANTED: 150mm dia x 15mm wall Ali pipe
By r0bsk1 in forum Items WantedReplies: 9Last Post: 12-06-2014, 04:19 PM -
I need to build a tube profiling machine
By Paulgy80 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-04-2014, 12:58 PM -
3mtr CNC pipe profiling machine.
By D-man in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 23-08-2013, 08:49 PM -
New machine Ideas
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 19-09-2012, 10:18 AM -
Pipe thread in 22 tpi???
By Robin Hewitt in forum Machine DiscussionReplies: 3Last Post: 21-09-2010, 11:19 AM
