    Just check this video out, it shows what I was trying to explain....
    The interesting stuff starts around the 2 min mark, cutting large holes with a plasma, for your design the plasma would be replaced with a small router or Kress with something like a 6mm slot drill. Also it shows the machine drilling holes with a standard drill bit.
    Same principle as I was trying to explain though, just an X axis to travel along the centreline of the pipe, an A axis to rotate it and a Z to plunge through, Z would be optional but nice to have! Not sure why you would need a Y axis at all??
    You could also cut the ends of pipes so you can create your own 90 degree joints.
    Simples....!
  1. WANTED: 150mm dia x 15mm wall Ali pipe
    By r0bsk1 in forum Items Wanted
    Last Post: 12-06-2014, 04:19 PM
  2. I need to build a tube profiling machine
    By Paulgy80 in forum Gantry/Router Machines & Building
    Last Post: 13-04-2014, 12:58 PM
  3. 3mtr CNC pipe profiling machine.
    Last Post: 23-08-2013, 08:49 PM
  4. New machine Ideas
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 19-09-2012, 10:18 AM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
