Thread: Lead screw and drive nuts ?
I have a 12 X 3 trapezoidal tap if you want to make your own out of delrin/acetal. I can post it to you - if post it back when you're finished,
As for motor couplings - why not try dumpsterCNC - I am using their trapezoidal 12X3 couplings which connect to a 6.35mm motor shaft.
Get bigger bearings with a 12mm bore to support your lead screw (I may even have some of those spare in the garage - if not they are pretty cheap)
Nathan
Delrin Lead nuts.
By Kammo1 in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 27-01-2016, 08:36 PM -
timing belt instead of lead screw
By deannos in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 06-03-2012, 08:25 AM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM -
x-axis rails and lead screw
By adambrum in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 13-08-2011, 01:56 PM
