Hi, I'm in the middle of a similar project. So far I am good for 0805 parts, 3216 LEDs, SOT23 parts.
Re your query about software:
Mine does not have a vision system, it simply depends on accuracy of the machine driven via Mach 3 and GCode. But I don't do manual GCode.
I have a Excel Workbook with a separate spreadsheet for:
- Heads
- Feeders
- PCB Array offsets
- Each PCB
- GCode output
For each PCB I paste in the Pick Place export from my PCB CAD package. I manually redit rotation, and enter a head and feeder. I paste in a block of formulas alongside.
I then manually enter a step sequence (gives a small leeway to optimise pick up order for efficiency)
The aforementioned formulas reference the Head & Feeder sheets to calculate pick and place offsets for each head/feeder combination, and place offsets for each head/refdes combination
I also update worksheet PCBArray with the PCB name and no of PCB's in X & Y directions for this assembly run.
I then run a macro over the above which for each rotation generates GCODE to:
- Initialise all Mach 3 variables used per feeder to keep count of the the next component to come out of that feeder
Main loop:
- Pauses waiting for operator (me) to place the PCB array holder and use the USB camera to zero offset G55 to the PCB holder calibration point
- calculates and sets an offset for each PCB in the PCB array relative to G55 offset for that rotation
- creates calls to the GCode pick place subroutine for all refdes in this rotation
- creates the GCode pick place subroutine called above
= Repeat until all rotations processed
Once a PCB is setup in the workbook (which only takes 5-10 min) can be tweaked quickly, ie if a head is faulty I just edit the heads per refdes and rerun the Macro.
Seems to work so far.
ID:	3533Click image for larger version.
ID:	3534Click image for larger version.
ID:	3535Click image for larger version.
