Thread: Robin's smt Pick and Place build
25-01-2012 #31
Thanks. Interesting idea re. the tape feeders. I've not put a great deal of thought into feeders yet as I'll probably add them after the rest of the machine is built. So far my very embryonic plan is to actuate each feeder individually with its own low cost DC motor and worm gear drive winding the cover tape over a roller to separate it from the main tape and onto a spool. I'll use some sort of hairpin switch to index the tape via its sprocket holes. I am, of course, hoping that most tapes will cope with being pulled forward via their cover tapes rather than their sprocket holes even though this is not how things are intended to be done.
Matt.
05-08-2012 #32
05-08-2012 #33
24-11-2012 #34
I've got a bit stuck working out the tape feeders, here's a whacky idea...
Remember that famous drill that cuts a square hole? I think I can use that idea to convert rotary to rectilinear motion. A conversion that can get complicated PDQ when you try to draw the mechanism.
The problem is advancing taped components. I want to drop a pin vertically into an index hole, move it forwards exactly 4mm then lift it vertically clear.
With one pin for all tapes, I can have lots of tapes because they can be closer together. The pin feeder mechanism moving with the gantry.
So, using the square drill idea, the plate holding the pin has 2 square holes in it. The holes fit over two oddly shaped shafts turning 2mm off centre. One rotation advances the tape 4mm.
Picture shows 18 degrees in 30 degree steps
27-11-2012 #35
Okay so I didn't quite understand the mysteries of the Reuleaux triangle but I do now.
My rounded out Reuleaux. without the pointy bits. looks okay but the centre doesn't move in any approximation of a circle
The centre of a true Reuleaux, constrained in a square, follows a sort of circle defined by the ends of 4 elipses. Mine looks like a finger painted flower
I can get true vertical/ horizontal motion if I fix the square and float everything else.
I have ordered gear wheels and lumps of brass, so I have until that arrives to simplify it.
28-05-2013 #36
are you still working on the project?
regards
Colin
28-05-2013 #37
29-05-2013 #38
03-01-2015 #39
If your still working away on this as a back burner thing this may give some inspiration :)
http://www.eevblog.com/2014/11/19/ee...-factory-tour/
Stuart
Brians Pick and Place Project
By briand in forum Pick & Place MachinesReplies: 4Last Post: 08-02-2014, 04:45 PM -
JuKu's pick and place project
By JuKu in forum Pick & Place MachinesReplies: 3Last Post: 09-12-2012, 08:42 PM -
Starting point for a pick and place - cheapy CNC and convert or build my own?
By 8086 in forum Pick & Place MachinesReplies: 18Last Post: 30-11-2012, 03:20 PM -
FOR SALE: MAMIYA ECM85MK2 Pick Place
By pdl in forum Items For SaleReplies: 2Last Post: 06-10-2011, 01:20 AM -
Pick and place log
By Robin Hewitt in forum Pick & Place MachinesReplies: 4Last Post: 22-10-2010, 03:00 PM
