Cheers.
My aim is to have all the high voltage run along the top of the cabinet in that photo (which is actually the bottom once the cabinet gets folded back-up), and the low voltage along the bottom.
If it wasn't for the fact I'm using the C23 board, I'd probably reorganise things a bit better, but it's a big board, and combined with the Smoothstepper, it takes up pretty much half the height of the cabinet from the capacitors along to the cooling fan, so it's a case of fitting things around it.
In hindsight, I should of probably ordered a G540 instead of G251s :-/
are these a newwer version usb break out board the ones from austrailia - better?
By nobby in forum General ElectronicsReplies: 0Last Post: 13-02-2014, 07:09 PM -
Break board 3-axis optical isolation, simple!
By thjremy in forum Electronic Project BuildingReplies: 0Last Post: 06-04-2013, 04:42 PM -
optoport v3 break out board wiring
By lez allen in forum Motor Drivers & ControllersReplies: 4Last Post: 26-02-2013, 07:38 PM -
Requirements on a break out board?
By Sodster68 in forum Motor Drivers & ControllersReplies: 3Last Post: 21-01-2013, 02:58 PM -
Controller Board Getting Very Hot / Allegro A3977
By MikeVA in forum Motor Drivers & ControllersReplies: 11Last Post: 08-09-2008, 03:04 AM
