I use a Maplins one N78AR... It 50W, has precision tips, and they stock the spare ones too... on special promo til 24/12/10... not bad for £20
21-11-2010 #2
I've had about 6 of those before i gave up and bought a better one, none of the six lasted the length of the warranty. Element failure, and yes you've guessed it you can't buy a replacement element. So i bought an N89CZ, which has worked flawlessly for a couple of years now.
http://www.maplin.co.uk/Module.aspx?ModuleNo=218050
21-11-2010 #3
Thanks for everyone's input.
Time will tell if i made the right choice.
Update got the new iron and it is so good compared to a fixed temperature type, very little black crud that i used to get building up on the old iron.
PhilLast edited by M250cnc; 26-11-2010 at 04:28 PM.
FOR SALE: How to measure the use of the imperial bearing temperature
By uitshguai in forum Items For SaleReplies: 3Last Post: 27-04-2014, 01:36 PM -
DIY RSU resistance soldering
By Boyan Silyavski in forum Electronic Project BuildingReplies: 1Last Post: 21-03-2014, 10:51 PM -
RFQ: Marking a cast iron
By mike stat in forum Projects, Jobs & RequestsReplies: 1Last Post: 13-09-2012, 10:22 PM -
RFQ: Small parts CNC machined from iron
By luc in forum Projects, Jobs & RequestsReplies: 1Last Post: 20-06-2012, 09:24 PM -
NEW MEMBER: hey guys, help fom experienced fanuc controlled cnc programmers needed. thanks
By benread89 in forum New Member IntroductionsReplies: 1Last Post: 18-08-2011, 04:20 PM
