    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 9-10 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    I have one of those Maplin irons, they work quite well but it's worth noting that the dial does not control the tip temperature rather it controls the power applied to the tip.
    I also have one of these
    http://cgi.ebay.co.uk/Weller-Solderi...item1c173c6f91
    true control of the tip temperature is achieved by selecting the correct tip for the job. You may get this for £50, it may go for more as the Iron alone can fetch £60.
    http://cgi.ebay.co.uk/WELLER-TCP-Tem...item1c16b01064
    http://cgi.ebay.co.uk/Weller-TCP-S-M...item2a0bc34b78
    My basic advice, search for Weller soldering iron or Weller station. Not cheap and the really good stuff does not often make it to the uk bay :(
    edit: Nice http://cgi.ebay.co.uk/Weller-Profess...item4cf320ab39 :)
    I've seen some favorable comments on some the Chinese base station + iron sets, I'll post back if I find them. I also know for fact that the 3 Chinese combos in the office downstairs allow true tip temperature control but also require new tips/elements every couple of months!
  2. Quote Originally Posted by ecat View Post
    Yes I was aware of that, but still does a good job for £20.. good for PCB stuff, not so good for big power cabling or big stuff to a ground plane (e.g. heatsink tags)
    Funnily enough so do I, tho mine is an older 80W version I think... still use the original tip - must be 30y old now. Only used for the bigger jobs...
    Irving & ecat thanks for the help,
    The Weller ones look nice, i will be doing minimal amount of soldering so if you find those Chinese ones so i can have a look that would be great.
    Phil
  1. FOR SALE: How to measure the use of the imperial bearing temperature
    By uitshguai in forum Items For Sale
    Last Post: 27-04-2014, 01:36 PM
  2. DIY RSU resistance soldering
    By Boyan Silyavski in forum Electronic Project Building
    Last Post: 21-03-2014, 10:51 PM
  3. RFQ: Marking a cast iron
    By mike stat in forum Projects, Jobs & Requests
    Last Post: 13-09-2012, 10:22 PM
  4. RFQ: Small parts CNC machined from iron
    By luc in forum Projects, Jobs & Requests
    Last Post: 20-06-2012, 09:24 PM
  5. NEW MEMBER: hey guys, help fom experienced fanuc controlled cnc programmers needed. thanks
    By benread89 in forum New Member Introductions
    Last Post: 18-08-2011, 04:20 PM
