22-02-2011 #29
looks like an interesting solution. Looks like it was well covered in the thread so I will not regurgitate that here, but how would that work with large pitch (high lead) screw like the one fitted to your mill. You may only end up with one or two line contacts per bearing? I guess it is not an issue with the type of duties our mills see. Obviously you will have to post results when you get onto manufacture!
Nice job on the refurb by the way.
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
RFQ: small cutout panel 66mm x 44mm - stainless steel 1mm thick
By dsc in forum Projects, Jobs & RequestsReplies: 2Last Post: 18-06-2012, 09:47 AM -
RFQ: small machining job??
By Wobblybootie in forum Projects, Jobs & RequestsReplies: 8Last Post: 25-02-2011, 01:04 PM -
Request for two small steel rod-esque lathed part!
By HankMcSpank in forum General DiscussionReplies: 42Last Post: 29-06-2009, 02:32 PM
