Thread: UK cnc kit suppliers
Probably your best bet would be to read through some of the build logs, this will help explain a lot of things you may have questions about & give you a better insight into individual components which vary in cost tremendously as do complete machines.
Unlikely you are going to be able to buy a machine that will do everything you want it to well with that sort of budget. What sort of size machine you would like will also play a big factor.
30-07-2013 #2
thanks for the reply. sorry for my very tardy response.
Actually a relatively small device is required - desktop size for small metal pieces for models/small prototypes and circuit boards. The build logs look interesting but experimenting seems expensive and I can't make sophisticated parts myself.
30-07-2013 #3
30-07-2013 #4
Be careful if your looking to buy one of these, the physical size might be just what your needing but if you are looking to cut metals then it might not do such a good job.
30-07-2013 #5
30-07-2013 #6
DIN rail and fittings suppliers
By Neale in forum Marketplace DiscussionReplies: 5Last Post: 19-05-2014, 10:14 AM -
servo controller suppliers
By spluppit in forum Motor Drivers & ControllersReplies: 0Last Post: 25-04-2013, 03:02 PM -
Cheapest suppliers of Alu?
By Shinobiwan in forum Marketplace DiscussionReplies: 10Last Post: 02-01-2013, 08:34 PM -
Acrylic suppliers
By Web Goblin in forum General DiscussionReplies: 2Last Post: 24-10-2011, 09:11 PM -
Aluminium Extrusion suppliers?
By m_c in forum General DiscussionReplies: 3Last Post: 12-04-2011, 01:23 AM
