29-11-2010 #9
You could use solidworks to trace the part if it can import an image to trace or use inkscape as I described and then import the DXF into solidworks. I've used solidworks in the past and it's a great program but it does take a bit of getting used to. No experience of solidcam I'm afraid.
Alternatively you could measure it carefully and create the sketch in solidworks from the measurements.
If I remember correctly, you'll need to create a sketch of the outline and then extrude that to the thickness of the plate. You then create sketches on the face of that part to define the holes / pockets / counterbores and create extruded cuts from those sketches. I'm not sure how solidcam works but in cambam you would then use the outline to create a profile machining operation (MOP) and then the other shapes to create pocket or drill MOPs.
FOR SALE: Denford Starmill
By Bartell in forum Items For SaleReplies: 1Last Post: 12-11-2014, 09:54 AM -
FOR SALE: Denford Starmill with ATC
By suesi34e in forum Items For SaleReplies: 0Last Post: 10-10-2014, 07:19 PM -
FOR SALE: Denford Starmill Mach3 Converted
By ricey3 in forum Items For SaleReplies: 2Last Post: 25-11-2013, 03:24 PM -
FOR SALE: Denford Starmill coverted to Mach3
By Kai in forum Items For SaleReplies: 0Last Post: 02-06-2011, 12:30 PM -
Denford Starmill
By Phil Gravett in forum Computer SoftwareReplies: 6Last Post: 27-05-2009, 12:05 PM
