Thread: MY 4`x 4` table
11-11-2008 #41
Well yesterday I stripped it down and painted it in Blue smooth Hammerite, turned the heater on it and left it to cook for a few hours, then came back this morning and put another coat on it and cooked it again then spent the rest of the day putting it back together. I managed to get the gear rack to within .04mm that works out to about 0.0015" from one end to the other and all bolt points in the middle on my DTI off the linear rail carriage.
I have finally got it moving at 10,000mm a min, soft limits are fine it stops at 1299.997mm on the DRO, the setting is 1230mm. I do still have a small problem, the "Slow Zone" dose not seem to be working, It goes from full speed to stop instantly, I will have to look into it and see what I have done wrong
Well Robin I had to make it even heavier, but I just could not leave it so I took it up to the old workshop and got it nice and warm and hit it with hammerite smooth blue
Its time to start making the base table now, Hopefully the other 2 Geckos are on there way and I still need to order 2 more motor
a short Video of it moving
http://s163.photobucket.com/albums/t...t=DSCF0790.flv
Very nice mate ! i wish i had the kinda space you'v got !
Thanks Lee, not my place, the buildings and grounds belong to My Friend, I just have free run of it all, its my workshop, in return for helping him out now and again, it works both ways, for both of us,
The pics where I painted it was my old workshop, before it moved to the new building, its a bit big 5000 Sq Ft, the workshop is about 1000 Sq Ft and colder than the old one
Steve
07-12-2008 #44
Hi All
Just a quick update, I have started on the table ( will get some pictures tomorrow ) for reasons beyond my control I have made it into a 6`x 4` table, I had 2 off 2Mtr gear racks for the X - A axis and had to buy the cold rolled steel for the runners in 3Mtr lengths so rather than cut a good bit off them and waste it I had another look at the cad drawings and managed to get a 2.5Mtr length table with 1950mm travel in the X-A and 1220mm in the Y from the material I had, from 2 full lengths of 7.5Mtr of 60x60x3 box I only had 2 pieces 40mm long scrap, but I do need to buy another length of something to carry the material supports and the water trough ( if I fit one)
But standing in the workshop it looks big, and I have yet to put caster on it
Steve
29-12-2008 #45
Happy Chrismas and a prosperous New Year to all
just a few pictures for those interested, 4`x 4` taple turned into a 6` x 4` table for no extra cost, I did hope to get the 3"x1/2" Bright bar (coled rolled) for the "X" runners before Christmas but missed the stockholders they closed early, so still need to get them yet.but this is how it should sit, I will put jacks on the corners eventualy, when I work out how or even what I want, Any one any ideas??
The control box is now finished for 4 axis and works well I still need to get a THC from Jim Cullins at Sound Logic, and 2 more motors for "X" then I can mount gear racks, slatted bed, and "Roberts your Fathers brother!" finished play time begins..... oh and of course PAINT it blue
did try to upload more photos but after emailing them to my self 4 times to reduce size I still cant get some of them small enough, sorry.
all the best
Steve
29-12-2008 #46
Download a copy of GIMP, this will allow you to resize/recompress pics and a whole lot more...
or download any number of of shareware jpeg image resizing/compression tools... which will allow you to select the appropriate image size & compression setting (typically 50% or better) to reduce file size
29-12-2008 #47
Hi
Thanks I did have microsofts Power toys in xp but in vista the only way I found was to email them to myself, will try them cheers
Steve
Looking good steve, cant wait to see it in paint.
"Roberts your Fathers brother!" uncle is that you ?, i have a Father ? :D
Ill have a look at the image upload spec's for the forums and the gallery and so on, i'm postive i have set "no limit" to image size in terms of the file size.Lee
Hi guys take a look here:
http://www.mycncuk.com/forums/showth...=2273#post2273Lee
30-12-2008 #50
Setting my table up...
By Davek0974 in forum Plasma Table MachinesReplies: 23Last Post: 10-03-2014, 08:24 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
Plasma table 2m x 1m
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 9Last Post: 19-05-2009, 12:48 PM -
Clamp table
By Lee Roberts in forum Programmers CornerReplies: 2Last Post: 14-10-2008, 03:03 AM
