Thread: MY 4`x 4` table
25-10-2008 #31
Hi all
Just a bit of a update, I have spent a few weeks collecting bits for the controller, and this is what I have, Campbell Designs excelent Break out board, a Sound Logic Power board with a 500va transformer together they give me 50v dc, and Gecko G203 Vampire drives (Im still 2 short but funds allowing I will order those this week), all in a 2U rackmount case with power and E Stop on front and all plugs on back
Steve
25-10-2008 #32
Thanks for the support, its nice to know people out there are interested
Im not even sure I want wood near it I dont do wood well, you cant weld a bit back on when you make a cock up, but it dose keep you warm, providing it will fit in the wood burne, but I may just try it out, but on the whole not realy bothered, I do have room on the back or under the gantry for a second rail but only if I realy need one, Buying the first made my eyes water
Steve
26-10-2008 #33
Thats some amount of money! you can probably add the same again for bearings, and the same again for a controler setup all without the cost of the frame. When you think about it these things can seriously harm your wealth! and mine is going to be just a toy! :D
Steve
26-10-2008 #34
That was the reason I decided to build mine myself from well known parts, my motors are 4.5a so I needed large drivers and gechos 203`s are suposed to be one of the best, the Vampire has a nice trick with microstepping and speed it morphs out of microstep, together with the power board and BOB were all designed to work together, all I had to do was find a case and transformer then spend a day wiring it all, hopefully I still have enough room be it on a second layer to get Jim Cullins THC in I did want a CandCNC one that included the Torch Head Control and BOB all in one, but they did not want to send to England something about lead content
Steve
26-10-2008 #35
26-10-2008 #36
27-10-2008 #37
27-10-2008 #38
27-10-2008 #39
Hi Kip
I`m trying to learn it, I seem to have some problems with my setup, but I don't know what I have done, this is my first play with cnc of any kind, ever so I'm a complete novice
1/ when I REF ALL HOME it hits the first switch ( all 3 are the same switch on each axis ) reverses off and ESTOPS!
2/ unless I change the % value in soft limits to 100% I can only get 20% speed
I have copied Bobs xml for the break out board, step by step manually into mach3 plasma. I think its in homing - limits my table is 1250mm square A & X are slaved, so soft max = 1250, soft min = 0, slow zone = 25, home off = 0.00 for X,Y,A and soft max = 0.00, soft min = -140, slow zone = 12, home off = 0.00 for Z
motor = 159.154 steps per, 10000 velocity, 1250 acceleration,
If you can help You will be My hero, I have fought with this for near a month, I have asked on most of the forums, and never got a reply,
Any body else any ideas??
Thank you in anticipation,
Steve
29-10-2008 #40
Setting my table up...
By Davek0974 in forum Plasma Table MachinesReplies: 23Last Post: 10-03-2014, 08:24 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
Plasma table 2m x 1m
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 9Last Post: 19-05-2009, 12:48 PM -
Clamp table
By Lee Roberts in forum Programmers CornerReplies: 2Last Post: 14-10-2008, 03:03 AM
Not sure how it will work out as a router with the single bearing on the Y axis...Either way some good quality work you've done so far!
