Thread: MY 4`x 4` table
Page 5 of 7 FirstFirst ... 34567 LastLast
  1. #41
    Well yesterday I stripped it down and painted it in Blue smooth Hammerite, turned the heater on it and left it to cook for a few hours, then came back this morning and put another coat on it and cooked it again then spent the rest of the day putting it back together. I managed to get the gear rack to within .04mm that works out to about 0.0015" from one end to the other and all bolt points in the middle on my DTI off the linear rail carriage.
    I have finally got it moving at 10,000mm a min, soft limits are fine it stops at 1299.997mm on the DRO, the setting is 1230mm. I do still have a small problem, the "Slow Zone" dose not seem to be working, It goes from full speed to stop instantly, I will have to look into it and see what I have done wrong
    Well Robin I had to make it even heavier, but I just could not leave it so I took it up to the old workshop and got it nice and warm and hit it with hammerite smooth blue
    Its time to start making the base table now, Hopefully the other 2 Geckos are on there way and I still need to order 2 more motor
    a short Video of it moving
    http://s163.photobucket.com/albums/t...t=DSCF0790.flv
  2. #42
    Very nice mate ! i wish i had the kinda space you'v got !
    .Me
  3. #43
    Thanks Lee, not my place, the buildings and grounds belong to My Friend, I just have free run of it all, its my workshop, in return for helping him out now and again, it works both ways, for both of us,
    The pics where I painted it was my old workshop, before it moved to the new building, its a bit big 5000 Sq Ft, the workshop is about 1000 Sq Ft and colder than the old one
    Steve
  4. #44
    Hi All
    Just a quick update, I have started on the table ( will get some pictures tomorrow ) for reasons beyond my control I have made it into a 6`x 4` table, I had 2 off 2Mtr gear racks for the X - A axis and had to buy the cold rolled steel for the runners in 3Mtr lengths so rather than cut a good bit off them and waste it I had another look at the cad drawings and managed to get a 2.5Mtr length table with 1950mm travel in the X-A and 1220mm in the Y from the material I had, from 2 full lengths of 7.5Mtr of 60x60x3 box I only had 2 pieces 40mm long scrap, but I do need to buy another length of something to carry the material supports and the water trough ( if I fit one)
    But standing in the workshop it looks big, and I have yet to put caster on it
    Steve
  5. #45
    Happy Chrismas and a prosperous New Year to all
    just a few pictures for those interested, 4`x 4` taple turned into a 6` x 4` table for no extra cost, I did hope to get the 3"x1/2" Bright bar (coled rolled) for the "X" runners before Christmas but missed the stockholders they closed early, so still need to get them yet.but this is how it should sit, I will put jacks on the corners eventualy, when I work out how or even what I want, Any one any ideas??
    The control box is now finished for 4 axis and works well I still need to get a THC from Jim Cullins at Sound Logic, and 2 more motors for "X" then I can mount gear racks, slatted bed, and "Roberts your Fathers brother!" finished play time begins..... oh and of course PAINT it blue
    did try to upload more photos but after emailing them to my self 4 times to reduce size I still cant get some of them small enough, sorry.
    all the best
    Steve
ID:	160   Click image for larger version.
ID:	161   Click image for larger version.
ID:	162   Click image for larger version.
ID:	163   Click image for larger version.
ID:	164   Click image for larger version.
  6. Quote Originally Posted by Steve-m View Post
    ... did try to upload more photos but after emailing them to my self 4 times to reduce size I still cant get some of them small enough, sorry.
    Steve
    Download a copy of GIMP, this will allow you to resize/recompress pics and a whole lot more...
    or download any number of of shareware jpeg image resizing/compression tools... which will allow you to select the appropriate image size & compression setting (typically 50% or better) to reduce file size
  7. #47
    Hi
    Thanks I did have microsofts Power toys in xp but in vista the only way I found was to email them to myself, will try them cheers
    Steve
  8. #48
    Looking good steve, cant wait to see it in paint.
    "Roberts your Fathers brother!" uncle is that you ?, i have a Father ? :D
    Ill have a look at the image upload spec's for the forums and the gallery and so on, i'm postive i have set "no limit" to image size in terms of the file size.
    .Me
  9. #49
  10. #50
    Ah but can you prove it, we only have your word for it Lee,
    How did that pic get in there? she said she would not show it, I have said it before never trust them!!;)
    Steve
  1. Setting my table up...
    Last Post: 10-03-2014, 08:24 PM
  2. DIY Vacuum Table
    By templecorran in forum Machine Discussion
    Last Post: 10-11-2010, 12:11 AM
  3. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  4. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
  5. Clamp table
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 03:03 AM
