  1. Mot sure about the Bob, but The measured voltage was 3.3V, which is on the border line of working for the optos.
    I have found that most support calls that end with the signal voltages being too low were on laptops.
    What breakout board is he using? The MDS drivers are optisolated so dont really need a sophisticated BOB and are pretty immune to cross-over noise on the signal lines due to the low impedance 'on' drive. Unless he has a very long cable from PC to BOB or the BOB is a old design with TTL rather than CMOS logic I'd be suprised that the use of a laptop was an issue.
    Quote Originally Posted by Gary View Post
    Don't say that after I've just spent £33 on a BOB! Not to mention having already spent £10 for the previous BOB which won't be used.
    I'll update this thread the moment I find something else worth reporting.
    Anyone else here using a CNC Fusion kit? I've had alignment issues with the Z axis in particular. Is it right that the entire weight of the Z axis is taken by the collar supplied in your kit? Also why is there so little space made around the LoveJoys? The Orange sticker peeled out on a couple - just shows how close they are to the walls.
  3. When we initially talked i presumed you were using our Bob, and this is a straight through bob with no components but two connectors.
    What bob are you using?
    Quote Originally Posted by bruce_miranda View Post
    I am using a similar BOB but was half the price and made by a CNC user, the board is milled on a CNC machine itself and comes with 4 PCB stand-offs.
    http://www.cncdoctor.co.uk/ParallelP...ard(P.004).pdf
  5. Quote Originally Posted by bruce_miranda View Post
    Bruce. That BOB MUST be used driving the opto's in ACTIVE LOW configuration. Its half the price because it has no active drive components, its just a connector. The PC on its own will not have enough output drive to drive the optos in active high mode. The signals on the MDSxxx are labeled thus Step+, Step- and Dir+, Dir- The - connections need to go to your driving signals and the + connections to a source of +3.3 or +5v power. This can be got off a USB connector, off a spare disc power connector inside the PC or via a cheap 5v regulated wall-wart. See pic.
  6. Quote Originally Posted by bruce_miranda View Post
    Bruce. That BOB MUST be used driving the opto's in ACTIVE LOW configuration. It will not have enough output drive to drive the optos in active high mode. The signals on the MDSxxx are labeled thus Step+, Step- and Dir+, Dir- The - connectoins neednto go to your driving signals and the + connections to a source of +3.3 or +5v power. This can be got off a USB connector, off a spare disc power connector inside the PC or via a cheap 5v regulated wall-wart.
  1. Replies: 0
    Last Post: 11-06-2014, 12:17 PM
  2. Leadshine 4-axis motor motion control cards? Any experience and info?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 02-12-2013, 06:43 PM
  3. CNC Motion control
    By StoneyCNC in forum Manufacturer News
    Last Post: 26-08-2013, 10:07 AM
  4. 2x Motors, 2x drivers. How about breakout?
    By Tenson in forum Motor Drivers & Controllers
    Last Post: 20-09-2012, 03:21 PM
  5. Time for a purpose built motion control computer.
    By GeoffV in forum General Computing
    Last Post: 08-11-2010, 01:11 AM
