09-09-2008 #21
I'm going to give Gary the benefit of the doubt here because he obviously knows his products better than I. So I've bought the only CNC4PC C1G breakboard board that was in stock. Hopefully this will solve my problem. If not then I'm back to the drawing board. Having said that the MSD542 manual does says that its looking for 4-5V for Active High and 0-0.5V for Active Low and since my laptop is giving 3.33V it may not be enought to kick the driver properly
09-09-2008 #22
Maybe you should strip everything back and set one up at a time and see if you can find the problem that way, i noticed kip said somthing about your SW's being set wrong on the other post.
I'v just merged this thread with the other one you started Bruce as they see to be about the same thing, be nice to see a new thread on the conversion of your mill after you hash these issues out.
LeeLast edited by Lee Roberts; 09-09-2008 at 07:32 PM.
09-09-2008 #23
I'll be doing a full write up of my entire set-up once things start working fine because I'm sure that are many like me who are complete novices and everything out there assumes you know something of CNC, plus there are very few UK only people who have a full write-up.
I was a bit too over confident and set-up everything into the box. If with the new BOB things don't start to work well then I'll have no other option but to start again.
09-09-2008 #24
09-09-2008 #25Visit Us: www.automationshop.co.uk
09-09-2008 #26
Don't say that after I've just spent £33 on a BOB! Not to mention having already spent £10 for the previous BOB which won't be used.
I'll update this thread the moment I find something else worth reporting.
Anyone else here using a CNC Fusion kit? I've had alignment issues with the Z axis in particular. Is it right that the entire weight of the Z axis is taken by the collar supplied in your kit? Also why is there so little space made around the LoveJoys? The Orange sticker peeled out on a couple - just shows how close they are to the walls.
09-09-2008 #27
Bruce, post your questions about the f-kit as a new one so people notice it other wise it could go un noticed mate. I'v also sent you a PM about the BOB you no longer will be using.
09-09-2008 #28Visit Us: www.automationshop.co.uk
09-09-2008 #29
I am using a similar BOB but was half the price and made by a CNC user, the board is milled on a CNC machine itself and comes with 4 PCB stand-offs.
http://www.cncdoctor.co.uk/ParallelP...ard(P.004).pdf
09-09-2008 #30
Bruce. That BOB MUST be used driving the opto's in ACTIVE LOW configuration. Its half the price because it has no active drive components, its just a connector. The PC on its own will not have enough output drive to drive the optos in active high mode. The signals on the MDSxxx are labeled thus Step+, Step- and Dir+, Dir- The - connections need to go to your driving signals and the + connections to a source of +3.3 or +5v power. This can be got off a USB connector, off a spare disc power connector inside the PC or via a cheap 5v regulated wall-wart. See pic.
Use of microstepping, external motion control boards, and related issues
By Neale in forum General ElectronicsReplies: 0Last Post: 11-06-2014, 12:17 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
2x Motors, 2x drivers. How about breakout?
By Tenson in forum Motor Drivers & ControllersReplies: 2Last Post: 20-09-2012, 03:21 PM -
Time for a purpose built motion control computer.
By GeoffV in forum General ComputingReplies: 17Last Post: 08-11-2010, 01:11 AM
