Aiming for Parallel and don't know what the wiring should be. So any help with be nice here.
Gary from Motion told me that the SW4 was meant only for dropping current down to half after a phase but I'm so lost now I'll try anything.
09-09-2008 #2
Wiring looks fine, and the current is set to 4.2 A so that should be ok also.
The problem that you are seeing is a typical noise or low signal problem, or possibly both.
These are the points you need to address:
1) Use Shielded cable for all signal cables
2) Shield the motor phase cables.
3) keep signal and power / phase cables apart, and if they need to cross, they should cross perpendicular.
Also check the signals from the pc, the voltage should be about 5V, it it is low the driver can miss pulses and you can get the stuttering you are seeing.Visit Us: www.automationshop.co.uk
09-09-2008 #3
I just had an email from Bruce, and it apears that his clock pulse is about 3.3V, and he is using a laptop.
This is most definately the problems, and is actually quite common when a laptop is used.
The solution would be to use either another laptop with higher voltage outputs, or a desktop PC with a parallel port.
Bruce,
Try this and give us your results.
Gary
09-09-2008 #4
What breakout board is he using? The MDS drivers are optisolated so dont really need a sophisticated BOB and are pretty immune to cross-over noise on the signal lines due to the low impedance 'on' drive. Unless he has a very long cable from PC to BOB or the BOB is a old design with TTL rather than CMOS logic I'd be suprised that the use of a laptop was an issue.
09-09-2008 #5Visit Us: www.automationshop.co.uk
09-09-2008 #6
Don't say that after I've just spent £33 on a BOB! Not to mention having already spent £10 for the previous BOB which won't be used.
I'll update this thread the moment I find something else worth reporting.
Anyone else here using a CNC Fusion kit? I've had alignment issues with the Z axis in particular. Is it right that the entire weight of the Z axis is taken by the collar supplied in your kit? Also why is there so little space made around the LoveJoys? The Orange sticker peeled out on a couple - just shows how close they are to the walls.
09-09-2008 #7Visit Us: www.automationshop.co.uk
09-09-2008 #8
I am using a similar BOB but was half the price and made by a CNC user, the board is milled on a CNC machine itself and comes with 4 PCB stand-offs.
http://www.cncdoctor.co.uk/ParallelP...ard(P.004).pdf
Use of microstepping, external motion control boards, and related issues
By Neale in forum General ElectronicsReplies: 0Last Post: 11-06-2014, 12:17 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
2x Motors, 2x drivers. How about breakout?
By Tenson in forum Motor Drivers & ControllersReplies: 2Last Post: 20-09-2012, 03:21 PM -
Time for a purpose built motion control computer.
By GeoffV in forum General ComputingReplies: 17Last Post: 08-11-2010, 01:11 AM
