Don't say that after I've just spent £33 on a BOB! Not to mention having already spent £10 for the previous BOB which won't be used.
I'll update this thread the moment I find something else worth reporting.
Anyone else here using a CNC Fusion kit? I've had alignment issues with the Z axis in particular. Is it right that the entire weight of the Z axis is taken by the collar supplied in your kit? Also why is there so little space made around the LoveJoys? The Orange sticker peeled out on a couple - just shows how close they are to the walls.
09-09-2008 #2Visit Us: www.automationshop.co.uk
09-09-2008 #3
I am using a similar BOB but was half the price and made by a CNC user, the board is milled on a CNC machine itself and comes with 4 PCB stand-offs.
http://www.cncdoctor.co.uk/ParallelP...ard(P.004).pdf
09-09-2008 #4
Bruce. That BOB MUST be used driving the opto's in ACTIVE LOW configuration. Its half the price because it has no active drive components, its just a connector. The PC on its own will not have enough output drive to drive the optos in active high mode. The signals on the MDSxxx are labeled thus Step+, Step- and Dir+, Dir- The - connections need to go to your driving signals and the + connections to a source of +3.3 or +5v power. This can be got off a USB connector, off a spare disc power connector inside the PC or via a cheap 5v regulated wall-wart. See pic.
09-09-2008 #5
Bruce. That BOB MUST be used driving the opto's in ACTIVE LOW configuration. It will not have enough output drive to drive the optos in active high mode. The signals on the MDSxxx are labeled thus Step+, Step- and Dir+, Dir- The - connectoins neednto go to your driving signals and the + connections to a source of +3.3 or +5v power. This can be got off a USB connector, off a spare disc power connector inside the PC or via a cheap 5v regulated wall-wart.
Use of microstepping, external motion control boards, and related issues
By Neale in forum General ElectronicsReplies: 0Last Post: 11-06-2014, 12:17 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
2x Motors, 2x drivers. How about breakout?
By Tenson in forum Motor Drivers & ControllersReplies: 2Last Post: 20-09-2012, 03:21 PM -
Time for a purpose built motion control computer.
By GeoffV in forum General ComputingReplies: 17Last Post: 08-11-2010, 01:11 AM
