Quote Originally Posted by bruce_miranda View Post
So the ACTIVE LOW configuration needs to be done in Mach3 for the Motor Outputs correct?
Yes you will need to tell the software which way up the signal is... The MDSxxx series of drivers recognise the rising edge of the signal so the PC must pulse the output LOW to cause the required motion.
