It could be an idea, but i still have to find a way to build a main assy that carry all parts.
Do you have a photo of a similar implementation ?
06-12-2010 #2
ccmarco
i had the same prob as you , i had a 12mm diameter trapezioid screw , so i turned the screw down to 8mm using a grinder and a drill as a lathe , threaded the end for a locknut , used a 100mm x 100mm x 10mm plastic shim with a 22mm hole drilled in it( to take a skate bearing) as a bearing block. so it went , thrust washer - bearing block (with skate bearing ) - thrust washer - locknut , tighten locknut to preload assembly , solid and cheap i have no lateral movement in screw ..... phew!!! maybe a pic would have been better
06-12-2010 #3
Hi John,
yes, a pic would be good.
It's all clear thrust washers aside.
Unfortunately the screwballs machining requires a good lathe and proper skills, any other attempt will fail unsafely.
Here in Italy, lathes are quite expensive, anyway i'm thinking to buy a little one at least to work small parts.
Could you take a shot of your assembly ?
Thanks,
Marco.
WANTED: FK12 fixed ballscrew support
By r0bsk1 in forum Items WantedReplies: 0Last Post: 29-10-2013, 10:21 PM -
minimum lead screw size and support bearing sizing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 30-03-2013, 04:51 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
