Hi, I'm converting the same machine and using the same motors (running bipolar parallel at 4.2A) and drivers as you are. The only exception is that I have milled nema mounts manually.
You're right about the collar, but there's little chance of anything going wrong with both collar and coupler locked up nice and tight. I'm only using one locking screw on my Z and it's fine.
I noticed your other post on your driver/motor issues and I'd be glad to post my settings and steps,timings and dip switch postions if you still need a rough guide to get them running better. I just completed all 3 axis last night and they're running fairly smoothly, although this machine needs constant tweaking to keep it running sweet, or so I'm told!
12-09-2008 #2
you're a saviour, yes please post all your settings for Step, Velocity, Acc, Pulse and Dir Width etc. Also what DIP settings have you used.
14-09-2008 #3
Just noticed your post. At work at the moment, but when I get home at 7pm I'll tear my controller case to bits and check and post everything you need to know. How's the conversion coming along?
FOR SALE: SEIG SX2 CNC Fusion Conversion for sale. Seoul/UK
By grunt-will in forum Items For SaleReplies: 8Last Post: 14-07-2014, 08:30 PM -
Mazatrol fusion 640M pc software
By hoezap in forum Mazak, Yamazaki MachinesReplies: 2Last Post: 19-05-2013, 09:59 PM -
CONVERSION: Sieg Super X3 conversion
By Sooty in forum Conversion Build LogsReplies: 0Last Post: 06-03-2013, 02:29 PM -
CNC Fusion Kit for Warco mini mill / Amadeal XJ12-300
By rnr107 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 03-07-2012, 01:18 PM -
Super X1 conversion - Lead Screw Pitch?
By bruce_miranda in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 19-09-2008, 01:29 PM
