    Dear all,
    Long story short I got hold of a great little cnc. However it also came with a problem. It's a 3-axis engraver that sits on top of a box in which all the electronics are.
    When I try to calibrate the axis from the machine's controls it makes alot of noise and does nothing. However if I move the axis individually I found that z moves fine, yet X and Y stalls when I press +/-. If want to move them at all I have to hit the +/- repetedly but it doesn't move much anyway.
    So the first thing I did was to check the motors and connections and I found that motors work great if I just use the Z controls for X or Y. I also measured the voltage going to the motors and they are all 12v.
    It does look like there is a problem with the main circuit board. Anyone out there have any ideas for tests I can do to narrow down the problem? I am starting to think that I will need buy another board.
    Cheers,
    Dan
    Hi Dan,
    From what you say it sounds like the X & Y are stalling.
    12v is very low and will limit your rapid speeds.
    What type of control are you using ?
    Phil
    Sent from my HTC Desire using Tapatalk
    I'm using the onboard controls, on the front of the machine. I don't have the software at the moment so just testing it manually.
    All motors are getting the same voltage so I assume the power supply is fine. If I switch the x or y feed to z then that motor travels Smoothly without any problems.
    On the surface it looks like there is something wrong with the x/y sockets on the control board but it does seem odd. I would have thought if there was a problem with the board then all axis would be effected or just one.
    Dan give more details of the control.
    Best sort out the writing first though
    Phil
    Quote Originally Posted by francooz View Post
    Dear all,
    Cheers,
    Dan
    It's possible you have bad driver components on the X and Y axes, is it possible to post pictures or details of the board? A picture / more details (manufacturer / model no etc) of the whole machine may also help.
    Mark
    Not sure what you are getting at.
    This is an image of the dash board. Controls on the left are for the router and on the right for the axis.
    Not sure how well you can see everything there. I'm not at home at the moment to take another picture.
    The white box to the right is where the power coming from; straight to the motors. On the circuit xyz is from left to right.
    I will find out the model number when I get back from work.
    There are people who read this forum with a lot of experience (I'm not one of them) and they may recognise the bit of kit and be able to suggest some tests. Looking at the picture of the board it would seem to be a fairly easy job to replace the driver ICs which would be much cheaper than getting a new board but you'd need to do more tests before knowing whether that would be a solution.
    Well if its an electronics problem then i will be no help whatsoever
    Phil
  10. The Following User Says Thank You to M250cnc For This Useful Post:
  11. #10
    Lives in East Lothian, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Are you sure the stepper driver power is coming from the white box?
    The white box looks more like a VFD to me, which should be connected to the spindle control panel and spindle...
    The silver boxes look more like a PSU for the stepper drivers...
    If the motors are moving when connected to the Z-axis, then it does sound like the driver board is at fault.
    Best thing is to see if there are any model numbers on the different parts, as somebody may be able to identify them.
  12. The Following User Says Thank You to m_c For This Useful Post:
  1. Y axis stalling
    By richie00boy in forum Machine Discussion
    Last Post: 11-09-2013, 10:37 AM
  2. rough traversing and stalling only in main screen
    By davethefixer in forum Machine Discussion
    Last Post: 12-05-2013, 08:34 AM
  3. DPC spikes stalling stepper motors
    By Mad Professor in forum Stepper & Servo Motors
    Last Post: 23-10-2011, 10:21 AM
  4. Clicking sound from stepper motor & stalling
    By francooz in forum Stepper & Servo Motors
    Last Post: 06-02-2011, 04:15 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
