Page 1 of 13 12311 ... LastLast
    my first cnc project from the start. as i type i am formating a pc that will be dedicated just to cnc.
    my board came today from ebay very fast delivery 2 days.
    i will post more as i get on.
  2. Ah, the ubiquitous TB6560 3-axis board from eBay... If you haven't already, you might want to search for TB6560 and look at other threads related to these boards...
    i have but pressed the buy it now!! i hope it gives me some probs so i can help others :)
    well got the pc up and running and the steppers all wired up plugged in and running
    no probs as yet
    hahahah!!! nice one chris... its ages since i was in that position watching them motors turn on the road runner g-code
    it was all magical mystical shit to me (still is a bit)
    iv got the 5 axis version of your board, my motors are a bit bigger than yours and dont really get hot at all on 24v, iv heard plenty of people reporting how hot the motors get, i think in some cases its pretty normal
    The motors make useful hand warmers this time of year :-)
    Mine run on the edge of too hot to touch and I haven't had any problems yet - 80 degrees C above ambient seems a common maximum.
  7. Quote Originally Posted by FatFreddie View Post
    I hope not... 85degC absolute case temp is the maximum recommended temp you should run a stepper at - higher than that and you risk internal breakdown and demagnetisation.... remember inside its going to be a lot hotter!
    an 85degC case is too hot to touch for most people. Maplin do a cheap £19 multimeter with a temp probe thats a useful bit of kit for playing with electrics...
    Sorry, yes - 130 degrees max internal which is about 85 degrees on the case. This website seems to think 70-80 degrees is normal - bit of a useless temperature that - hot enough to want to avoid touching but not hot enough to make tea.
    80 degrees above ambient is pretty tepid in my garage at the moment so I don't think it will be a problem for a while :-)
    Hot enough if you're 6700m above sea level!
    My motors (3nm size 23, 4.2A on 75v) rarely got hot. The vast majority of the time I can barely feel any temperature rise. It's only when the machine has been running for a long time that they start to get hot. I think the drivers reducing the current to 50% when stationary helps here.
    It makes me wonder if I can up the current a bit and get a bit more torque/speed. It's on 4.09A, could try 4.64A. That'd be up to 30% more heat I think (I^2*R), or 20% above rated power.
  10. What motors are those Chris?
  1. Well here we go again, start another build
    Last Post: 22-01-2014, 09:59 AM
  2. Build log when to start posting on this site
    By ramsbury in forum General Discussion
    Last Post: 15-01-2014, 10:43 AM
  3. NEW MEMBER: Hello all, finally ready to start a build log.
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Were do I start?!
    By tonygagey in forum New Member Introductions
    Last Post: 07-08-2010, 07:55 PM
