Page 6 of 13 FirstFirst ... 45678 ... LastLast
  1. #51
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    I get a radius of 20.207.
    I'd explain fully, but I'd need to do a drawing.
    It involves the constant that all the angles within a triangle add up to 180deg, and a bit trigonometry.
  2. #52
    ahh... i get it now, im with m_c on this one 20.07mm radius will intersect 3 points 35mm apart
    took me ages to work that out
  3. #53
    i can find the formula for 4,5,6 but not for 3 :confused:
    PCD Calculation Formula
    3 stud PCD = S / 0.866
    4 Stud PCD = S / 0.7071
    5 Stud PCD = S / 0.5278
    6 Stud PCD = S / 0.5
  4. #54
    3 stud PCD= S/0.866
    peter
  5. The Following User Says Thank You to ptjw7uk For This Useful Post:
  6. #55
    thanks peter star man, added it to the post :-)
  7. #56
    Ahh, now I understand the question! You wanted *diameter* not circumference at stated in your post.
    It's just cos(30)...
    Let x be side length of the triangle the three points form (i.e 35mm).
    (see diagram)
    Draw in lines on triangle that bisect the angles. So we've now got a smaller triangle with one side length x/2, and we know the angle indicated is 30 degrees, since it's an equilateral triangle and we've bisected the corner angle.
    cos(30)=(X/2)/r
    r=X/2/cos(30)
    r=17.5/cos(30) = 20.2072594...
    (since d=2r, d=X/cos(30))
    Incidentally to help remember it cos(30) is just sqrt(3)/2 = 0.866025...
    Hope that helps. You can get the other PCDs using similar methods. 4 is half root 2.
Name:	PCD diagram.png
  8. The Following User Says Thank You to Jonathan For This Useful Post:
  9. #57
    thanks jonathan ;-)
  10. #58
    Ahh just realised. My method can easily be extended to the general case for n bolts. You just need to know half the angle interior angle of the particular polygon. Then do cosine of that to get the factor...
    3 = Triangle, 60/2 = 30, so cos(30)
    4 = Square, 90/2 = 45, so cos(45)
    5 = pentagon, 108/2 = 54, so cos(54) = 0.5878 (!)
    6 = hexagon, 120/2 = 60, so cos(60) = 0.5
    The formula to find the interior angle is 180(n-2)/n.
    So that means, given n bolts with spacing x.
    r=x/(cos(90(n-2)/n))
    PCD = x/(2*cos(90(n-2)/n))
    enjoy!
  11. #59
    like the formulae but...
    er where is x used??
    there are 10 sorts of people in the world
    them as understand binary
    and thems as doesn't
  12. #60
    x=bolt spacing(centre to centre)
    Peter
  1. Well here we go again, start another build
    Last Post: 22-01-2014, 09:59 AM
  2. Build log when to start posting on this site
    By ramsbury in forum General Discussion
    Last Post: 15-01-2014, 10:43 AM
  3. NEW MEMBER: Hello all, finally ready to start a build log.
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Were do I start?!
    By tonygagey in forum New Member Introductions
    Last Post: 07-08-2010, 07:55 PM
