Page 8 of 13 FirstFirst ... 678910 ... LastLast
  1. #71
    how do you get started! i am using autocad then lazycam.
    say i have a 10x10 cm x 5mm piece of ally clamped on the mill bed, and want to put a hole in the center.
    how do i set mach3 up?
    1. load in the gcode.
    thats as far as i am can you help?
  2. #72
    easy way is to cut air to see where its start/reference point is
    you will have stipulated this when you drew it up
    it may need to be zeroed in on one of the corners of you block or it my start from the dead centre
    im guessing it depends on what the default is if you didnt stipulaite this yourself in lazycam
    i tend to cut air to kick of with, just run the first couple of lines to make sure youve not made any big mistakes
    edit: if you have a look in the tool path window in mach that should give you a clue as to where the tool will start from in comparison to where it will make the first cut
  3. #73
    mark the sooner you can come over to my house the better. before my head pops, did you get my text?
  4. #74
    no ? er hang on a mo my phone is flat
  5. #75
    got it, ill give you a shout later
  6. #76
    nice 1, i ordered my x and y motors yesterday :)
  7. #77
    Quote Originally Posted by h4ppy-chris View Post
    Maybe this will help
    http://www.mycncuk.com/forums/showth...9965#post19965
    Phil
  8. #78
    i was thinking the problem was more one of orientation between drawn part and machine bed and material... eg: sussing out the work flow from CAD to CAM to MACH to material
    youll have to let us know chris
  9. #79
    I have updated MY post to show the part is drawn in CAD at the lower R/H portion of XY Zero
    It doesn't make any difference in which position you draw it you just put it in the same position in Mach3
    Phil
  10. #80
    ok
    i think it might be it a little simpler to stipulate in cam that i was starting from a corner
  1. Well here we go again, start another build
    Last Post: 22-01-2014, 09:59 AM
  2. Build log when to start posting on this site
    By ramsbury in forum General Discussion
    Last Post: 15-01-2014, 10:43 AM
  3. NEW MEMBER: Hello all, finally ready to start a build log.
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Were do I start?!
    By tonygagey in forum New Member Introductions
    Last Post: 07-08-2010, 07:55 PM
