Page 7 of 13 FirstFirst ... 56789 ... LastLast
  1. #61
    Ahh just realised. My method can easily be extended to the general case for n bolts. You just need to know half the angle interior angle of the particular polygon. Then do cosine of that to get the factor...
    3 = Triangle, 60/2 = 30, so cos(30)
    4 = Square, 90/2 = 45, so cos(45)
    5 = pentagon, 108/2 = 54, so cos(54) = 0.5878 (!)
    6 = hexagon, 120/2 = 60, so cos(60) = 0.5
    The formula to find the interior angle is 180(n-2)/n.
    So that means, given n bolts with spacing x.
    r=cos(90(n-2)/n)
    PCD = 2*cos(90(n-2)/n)
    enjoy!
    my question is - none of these formulae use x - I'm sure they should somewhere?!?
    r= x/(cos(90(n-2)/n))
    PCD = x/(2*cos(90(n-2)/n))
    Last edited by mmcp42; 02-01-2011 at 04:03 PM. Reason: more correcter formula (mebbe??)
    there are 10 sorts of people in the world
    them as understand binary
    and thems as doesn't
  2. #62
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    should be x/cos(whatever), as you're working out the hypotenuse from the adjacent.
  3. #63
    fair do's
    I've updated by guesswork...
  4. #64
    Yes it is, sorry ... was rushing and missed that
  5. #65
    big time backlash on the z axis so time to investigate and here's what i found.
    and here's how i sorted it there was play between the bearings so skimmed 0.76mm of the end cap no more play backlash now down to 0.003
  6. #66
    well my ally turned up so made a start on the z motor plate
    all i could think of when making it was, if the mill was finished i would just be watching it being cut.
ID:	3552 Click image for larger version.
  7. #67
    Quote Originally Posted by h4ppy-chris View Post
    Similar to how I did it except I mounted the motor plate 90 degrees clockwise to yours, and lathed a bit of 3" aluminum bar to act as a spacer and give a bit more surface area for the motor plate to bolt on to. Doing it that way enables me to use the handle for manual drilling without removing the stepper - I think yours would collide?
  8. #68
    good point jonathan, i will wait till it's all working then make a new one.
  9. #69
    Here's a couple of photos of mine, pretty self explanatory...
Name:	DSC06875 (Small).JPG
ID:	3568   Click image for larger version.
Name:	DSC06874 (Small).JPG
  10. #70
    cheers mate that's give me some think to think about.
  1. Well here we go again, start another build
    Last Post: 22-01-2014, 09:59 AM
  2. Build log when to start posting on this site
    By ramsbury in forum General Discussion
    Last Post: 15-01-2014, 10:43 AM
  3. NEW MEMBER: Hello all, finally ready to start a build log.
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Were do I start?!
    By tonygagey in forum New Member Introductions
    Last Post: 07-08-2010, 07:55 PM
