    easy way is to cut air to see where its start/reference point is
    you will have stipulated this when you drew it up
    it may need to be zeroed in on one of the corners of you block or it my start from the dead centre
    im guessing it depends on what the default is if you didnt stipulaite this yourself in lazycam
    i tend to cut air to kick of with, just run the first couple of lines to make sure youve not made any big mistakes
    edit: if you have a look in the tool path window in mach that should give you a clue as to where the tool will start from in comparison to where it will make the first cut
  1. Well here we go again, start another build
    Last Post: 22-01-2014, 09:59 AM
  2. Build log when to start posting on this site
    By ramsbury in forum General Discussion
    Last Post: 15-01-2014, 10:43 AM
  3. NEW MEMBER: Hello all, finally ready to start a build log.
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Were do I start?!
    By tonygagey in forum New Member Introductions
    Last Post: 07-08-2010, 07:55 PM
