Thread: my build from the start
09-01-2011 #71
how do you get started! i am using autocad then lazycam.
say i have a 10x10 cm x 5mm piece of ally clamped on the mill bed, and want to put a hole in the center.
how do i set mach3 up?
1. load in the gcode.
thats as far as i am can you help?
09-01-2011 #72
easy way is to cut air to see where its start/reference point is
you will have stipulated this when you drew it up
it may need to be zeroed in on one of the corners of you block or it my start from the dead centre
im guessing it depends on what the default is if you didnt stipulaite this yourself in lazycam
i tend to cut air to kick of with, just run the first couple of lines to make sure youve not made any big mistakes
edit: if you have a look in the tool path window in mach that should give you a clue as to where the tool will start from in comparison to where it will make the first cutLast edited by blackburn mark; 09-01-2011 at 12:56 PM.
09-01-2011 #73
mark the sooner you can come over to my house the better. before my head pops, did you get my text?
09-01-2011 #74no ? er hang on a mo my phone is flatdid you get my text?
09-01-2011 #75
got it, ill give you a shout later
09-01-2011 #76
nice 1, i ordered my x and y motors yesterday :)
09-01-2011 #77
Maybe this will help
http://www.mycncuk.com/forums/showth...9965#post19965
Phil
09-01-2011 #78i was thinking the problem was more one of orientation between drawn part and machine bed and material... eg: sussing out the work flow from CAD to CAM to MACH to materialMaybe this will help
youll have to let us know chrisLast edited by blackburn mark; 09-01-2011 at 02:52 PM.
09-01-2011 #79
09-01-2011 #80okI have updated MY post to show the part is drawn in CAD at the lower R/H portion of XY Zero
It doesn't make any difference in which position you draw it you just put it in the same position in Mach3
i think it might be it a little simpler to stipulate in cam that i was starting from a corner
Well here we go again, start another build
By D-man in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-01-2014, 09:59 AM -
Build log when to start posting on this site
By ramsbury in forum General DiscussionReplies: 6Last Post: 15-01-2014, 10:43 AM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
A few questions before I start my build
By eclassic in forum General DiscussionReplies: 0Last Post: 11-07-2011, 10:54 PM -
NEW MEMBER: Were do I start?!
By tonygagey in forum New Member IntroductionsReplies: 4Last Post: 07-08-2010, 07:55 PM
