  1. #31
    Just thought I'd put my model with a few dimensions just to show how far out the machine is.
Name:	New Picture (1).jpg
ID:	3829Click image for larger version.
Name:	New Picture.jpg
ID:	3830Click image for larger version.
Name:	New Picture (3).jpg
ID:	3831Click image for larger version.
Name:	New Picture (2).jpg
  2. #32
    Hi Anstals,
    As you are using ballscrews you should have negligible backlash so i don't think that is you're problem.
    Looking at the finish on the part I'd say you have play in the jibs X &/or Y or the Z column could have excessive play in the housing.
    Have you checked the amount of backlash you have "Do you know how" ?
    Phil
  3. #33
    Phil,
    Thanks for the reply......no I need some guidence on how to check for backlash. Thats a good call on the jibs, I need to check them all I'm guessing they are tight enough when there is no movement?
    Ant
  4. #34
    Hi Ant,
    To adjust the jibs It's best to take the motors off so you can turn the ball screws by hand you can then FEEL for any binding so get them as snug as you can but no binding. The best place to do this is at the extremes of travel as this will be the tightest area.
    To test for backlash you need to have a DTI in a chuck or collet
    You gently come up to a smooth face zero the DTI and zero the DRO
    YOU CONTINUE TO WIND THE DTI ONTO THE FACE A SMALL AMOUNT 0.2mm say
    Then you gently back off the face until the DTI reads zero
    Your Backlash will be what the DRO reads
    Wind the Z down about 75mm put a dowel in a collet chuck have the dowel sticking out 30mm put the DTI on the dowel at It's end push and pull on the collet chuck to measure play in the quill/housing.
    Phil
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. CNC Turret Mill range
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 28-11-2011, 07:23 PM
  3. Warco WM16 Conversion
    Last Post: 25-03-2011, 09:32 PM
  4. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 07:48 PM
  5. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
