Thread: motor start capacitor
26-12-2010 #1
Hi guys i need a new start capacitor for my lathe
it a 1hp motor 240v single phase 5.2 amp but i dont now what size to get as the old capacitor has no info on it worn off any ides guys ???
26-12-2010 #2
Scott
You can pick up start capacitors from Maplins, size is not a problem as long as it fits onto the motor and the ratings are correct. If they are open then pop along to any electrical wholesalers..If the nagging gets really bad......Get a bigger shed:naughty:
26-12-2010 #3
I think when Scott said size he meant capacitance, which he can't read from the existing part!
Motor start capacitors are typically around 30uF per HP, my 1/2hp motor has a 12uF. The bigger the capacitor the larger the starting torque. For a lathe where there is little load at start, you might get away with a smaller one. Try 12uF and see... 440v rating.
26-12-2010 #4
thanks irving2008 your right i was after the correct capacitance / voltage i will try 12uf as there is very little starting torque required
new bearings smooth as a babys bum lol
thanks
26-12-2010 #5
LOL sorry guys i see the point. I had problems finding a cap to fit a shell on one of my motors until i tried a Maplins special. I followed the 12 - 15uf rule when i fitted mine as it was missing when i got the motor.
26-12-2010 #6
not to sound too stupid but whats the 12 - 15uf rule??
never had to mess with capacitors before first motor that i had to get one for lol
26-12-2010 #7
I think whats being refered to is that most small fractional HP motors have a start cap of 12 - 15uF, so if in doubt try one... the worst that will happen is hasn't got enough start torque to run....This assumes we are talking about a start capacitor and not a start/run... can you confirm that your motor has a centrifugal switch that disconnects the start cap once its about 3/4 speed.
27-12-2010 #8
Scott Irving is right and not worth worrying to much about it. 30uf is roughly the norm for 1hp motors, it's more about what you can get as a lot of intermediate sizes are not available to keep manufacturing costs down. You can always go to the nearest highest value without much problem. A lot of small garage machinery uses between 1/2hp and 3/4hp motors (bench drills) so 12 -15 becomes a reasonable rule. If your motor requires a greater start torque to get going then a smaller cap will not start it and you would need the next one up. I have an old 3/4hp motor that runs quite happily on an 8uf cap (go figure that), it has very high spec bearings and not a lot of resistance to get started so only needs a small kick. This i suspect is the manufactures being a bit frugal with costs and opted for the lowest value they could get away with?
27-12-2010 #9
thanks for all the info guys got one off ebay no real shop round here lol
28-12-2010 #10
Just one point worthy of note: single phase motors generally have one "start" capacitor to give it a kick on start up (where higher power demand is normal).
It won't generally be used to "run" the motor - motors which require capacitance on the "run" coil will often have a second, lower value capacitor for the "run" function, rather than use one capacitor for both functions.
Capacitor questions
By Fivetide in forum Electronic Project BuildingReplies: 25Last Post: 17-07-2013, 11:29 PM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start?
By trounce in forum Gantry/Router Machines & BuildingReplies: 44Last Post: 03-10-2011, 02:03 PM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM -
NEW MEMBER: Were do I start?!
By tonygagey in forum New Member IntroductionsReplies: 4Last Post: 07-08-2010, 07:55 PM
