Thread: my first plasma build
31-12-2010 #6
Adam,
I'm not quite sure what you have in mind for the chain drive but will see when you get some more photos posted.
Be careful of how much tension you put on the side bearings. They should only really be just touching the rail to keep the gantry straight. If you tighten then up too much then you could smash the bearing or jam the machine when it tries to travel. This could happen because of the chain twin drive system. If both of the chains do not move exactly at the same time and speed then the gantry will slew.
How accurate are you hoping your production parts will be?
I off to have a cry now. just came in from the new workshop that I am trying to get all my kit back into. I have stored all my stuff in the shed and just found my meddings drill head covered in water, ice and loads of rust. A length of flat bar had gone through the side of the roof vent and allowed water to run down it right into the drill head. A simple refit job has now turned into a restoration project.
Regards
Ian
My plasma build 8 x 4
By drumsticksplinter in forum DIY Plasma Build LogsReplies: 7Last Post: 01-02-2014, 10:39 PM -
my plasma build mk2
By oadamo in forum DIY Plasma Build LogsReplies: 8Last Post: 08-06-2011, 10:25 PM -
My first Plasma build
By D-man in forum Plasma Table MachinesReplies: 4Last Post: 10-07-2010, 02:27 AM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM -
plasma build log - sort of
By mike techserv in forum DIY Plasma Build LogsReplies: 0Last Post: 23-04-2009, 10:15 AM
