    Chas
    If the whole unit will not power up or just trips straight away, you have no bare wires then suspect the transformer itself. If it is only part of the lathe that does not work then it would be the contactor for that circuit (normally just the energising coil). There is not a lot that can really go wrong, i'm wiring a new lathe up from scratch at the moment myself. What does each contactor feed? tell us more about the controls? is the contactors controlling motor, pump, light etc?
    Chas's Avatar
    Lives in Nottingham(ish), United Kingdom. Last Activity: 09-03-2013 Has been a member for 9-10 years. Has a total post count of 55. Received thanks 2 times, giving thanks to others 2 times.
    Quote Originally Posted by 2e0poz View Post
    Chas
    In my picture from left to right.
    Contactor 1 = motor forward
    Contactor 2 = Motor reverse
    Contactor 3 = coolant pump
    Contactor 4= unknown
    I've just found out that pushing in the contactors gets the motor running regardless of the lathes forward/reverse switch.
    When I switch the lathe on, there is no 'clunk' like there used to be.
    Is contactor 1 at fault?
    Chas's Avatar
    First electric shock, luckily only 24v.
    A small crowd is gathering . . . . I might make some smoke before the day is done.
    Consider 230v contactors and do away with the 24v transformer? you may even be able to get new coils on there own for the contactors if they are removable.
  1. Honey I blew up the mini lathe speed control board
    By HankMcSpank in forum General Electronics
    Last Post: 23-01-2018, 09:39 AM
  2. Mach lathe spindle speed control
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 21-05-2014, 08:34 AM
  3. Bent ballscrews - is repair possible?
    By bee in forum Lead Screws, Nuts & Supports
    Last Post: 10-12-2013, 09:41 PM
  4. RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
    By Chas in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 09:28 AM
  5. CNC repair
    By 2006Nobull in forum Machine Discussion
    Last Post: 05-10-2010, 11:25 AM
