Thread: Single or double??
Ok Folks, Lead screw support bearings (fixed end) ... a pair of single row angular contact or a solo double row bearing??? that is the question.
Answers, as simple as possible but with reasons please.Tim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
	06-01-2011 #2
Tim,
a pair of single row angular contact bearings as you can eliminate any backlash. A single (inexpensive) double row bearing may or may not have backlash problems.Art
AKA Country Bubba
(Older than Dirt)
The Following User Says Thank You to C_Bubba For This Useful Post:
	06-01-2011 #3
I'm interested in the answer to this as I am at the design stage too
do you have a picture for the hard of thinking?there are 10 sorts of people in the world
them as understand binary
and thems as doesn't
	06-01-2011 #4
	06-01-2011 #5
	06-01-2011 #6
OK thanks for that ... I was leaning toward a pair of singles as that seems to be what most folks opt for ...
Tim G-C
	06-01-2011 #7
iv got single a/c bearings on my x axis screws at the moment,,,, im having problems with them being to tight on the shaft (my mistake) if i put to much tension on them i wont be able to back them off :( and to take them off the shaft i will damage them. anyway they have been a pain in the jacksy
iv bought two double row A/C's to put in (when i find the time) the only disadvantage iv spotted with the double row is there are fewer balls so lower stress raiting... i cant see this being a problem, they will have a very easy life on a router
if your getting any backlash worth mentioning with double row a/c I'd suspect that some cheeky sod has sold you double row deap grove bearings as angular contacts or they are duds
	06-01-2011 #8
Cheers, I'll bear those points in mind ...
Tim G-C
wobble / wiggle on ballscrew double row angular contact bearing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 14-12-2013, 08:35 PM -
Video of CNC machining a double sided part.
By Shinobiwan in forum Woodworking Project ShowcaseReplies: 26Last Post: 17-03-2013, 11:23 AM -
Double gantry idea, What do you guys think?
By craigrobbo in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 25-12-2012, 10:01 PM -
Single Flute vs. Ripper
By Tenson in forum Tool & Tooling TechnologyReplies: 11Last Post: 16-04-2012, 09:51 AM -
Double sided machining
By CraftyGeek in forum General DiscussionReplies: 7Last Post: 08-12-2009, 11:04 AM
