Thread: Starmill
Page 3 of 3 FirstFirst 123
  1. #21
    i2i's Avatar
    Yes, you would need three of these circuits one for each drive, and no the breakout board does not give you this feature.
    It's a simple circuit that you can pop on a small piece of veroboard and connect it between the breakout board and Parker stepper drives.
  2. #22
    Componants for 4 boards orderered (1 spare) I'll get soldering when they arrive. Not quite sure how to connect up or what my next stage is though.
  3. #23
    i2i's Avatar
    here's a link for the drives you have.
    http://www.denfordata.com/bb/viewtop...1&hilit=parker
  4. #24
    i2i's Avatar
    the only sticking point may be the spindle drive, as you'll need to find out what varies the speed and what enables the spindle. Normally there is a relay (SGR, spindle go relay) that enables the spindle, and an isolated 0-10v board that varies the speed.
  5. #25
    I will have a look tommorow to see if I can identify which of these drives I have. Thanks for that. Phil
  6. #26
Name:	stepper drives top.jpg
ID:	3606Click image for larger version.
Name:	speed control.jpg
ID:	3605I have hard a good look at the circuits in Click image for larger version.
Name:	Tool change PSU.jpg
ID:	3604the back of the Starmill. I can't be certain but out of the two types of drive on that Denford link you posted, the sd range looks closest.
Name:	stepper drives.jpg
ID:	3603 I have attached a few pics. On one of the motor boards- PKS Digiplan '87.
    The Spindle board is- Jay Electrical DC speed control JE124/1 seriClick image for larger version.
    The tool change psu 122ve.
    I have received parts from Maplin to make buffer but haven't got a clue where to connect up. Phil.Click image for larger version.
Name:	Tool Change.jpg
  7. #27
    i2i's Avatar
    have a look at the end of the stepper drive boards and it will state what type they are, probably a cd20 or sd 20. Page 23 of the digiplan drive manual shows the pinout for the end connector, and pins 26 and 28 of row c are the dir and clock positions. You'll need to find the wiring that feeds these signals into the drives and isolate them from the main board, then it's simply a matter of putting the buffer board between the breakout boards output and these points
  8. #28
    i2i's Avatar
    with the spindle board, do the red orange and brown wires go to a pot for varying the speed.
  1. FOR SALE: Denford Starmill Mach3 Converted
    By ricey3 in forum Items For Sale
    Last Post: 25-11-2013, 03:24 PM
  2. Dimensions and Weight of Denford Starmill PC Please
    By cristec in forum Milling Machines, Builds & Conversions
    Last Post: 13-08-2012, 07:02 AM
  3. FOR SALE: Denford Starmill coverted to Mach3
    By Kai in forum Items For Sale
    Last Post: 02-06-2011, 12:30 PM
  4. Denford Starmill
    By Phil Gravett in forum Computer Software
    Last Post: 27-05-2009, 12:05 PM
