    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    8mm reamer would be the way to go, or 5/16" would give 7.935mm, but that may be just too small even for a shrink fit.
    If you get a shaft which is 8.000mm and a bearing, you won't get the bearing on the shaft without a decent amount of force. So I reckon 8mm reamer is good as I read somewhere you'd need 8.05mm to get a 'just slides on' fit.
  1. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  2. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 06:47 AM
  3. aluminium machining
    By drumsticksplinter in forum Gantry/Router Machines & Building
    Last Post: 15-03-2013, 12:19 AM
  4. BUILD LOG: small mill for machining steel. Max spend £500 including computer
    By Andrew Wilding in forum DIY Mill Build Logs
    Last Post: 20-07-2012, 03:46 PM
  5. Machining odd shapes on a denford starmill
    By Kai in forum Denford Mills
    Last Post: 02-12-2010, 06:52 PM
