Thread: Software info
    Hi all,
    just wondering if anyone has experience of any software that has lettering built in for sign work. In the past I have drawn up the alphabet and numbers 0 to 9 in Autocad and it took quite a while and I really wouldnt like to have to do it again.
    Regards
    Ian
    Try CamBam - http://www.cambam.co.uk
    You get 40 goes free which is plenty to try it out
    There's linear text support built in and a plugin for curved text (ArcText) have a look in the forum as well.
    Mark
    Vectric has some software fit your application.
    It has 30 day trials and has a very good reputation but I have never used it
    Phil
    Sent from my HTC Desire using Tapatalk
    Had a look at Cambam and it seems ok but produces alot of lines of code. I will have a look at the vectric option and see what thats like.
    Ian
    Ian
    Hi Ian i think what ever software use you use is gonna produce a lot of lines of code
    Phil
    Quote Originally Posted by M250cnc View Post
    I've found that too. I'm guilty of it myself - when I wrote a program to calculate and cut he profile of wind turbine blades I just made it move in lots of straight lines. So much easier than arcs, more lines yes....but it doesn't make much difference if you use G64.
  1. Pilz Relay info
    Last Post: 08-05-2014, 10:16 PM
  2. Replies: 2
  3. NEW MEMBER: Hello from Ireland..........Need info....
    By aquila787 in forum New Member Introductions
    Last Post: 10-09-2012, 10:09 PM
  4. BUILD LOG: second build, thanks for all the info.
    By tonyken in forum DIY Router Build Logs
    Last Post: 11-04-2012, 10:32 PM
  5. Info on V23
    By m.marino in forum CAD & CAM Software
    Last Post: 14-10-2009, 09:18 PM
