Thread: Needed for my build
My y axis is only going to be used to wind out by hand to a position then locked off, ballscrew is overkill really but I want the anti backlash etc
If im only needing 1000mm/min with a 5mm pitch then its only gona be turning at 200rpm wich I think will be fine
08-01-2011 #2
Yes I'm sure 200rpm will be fine, so long as your happy waiting 2 minutes to traverse the whole bed.
Surely if you're operating the Y axis by hand then you can compensate for the backlash by hand, as one would normally when using a manual machine? I suppose not having backlash helps get a good finish as you can use climb milling...not sure if that's an issue cutting rubber.
You might want to consider the drive mechanish I used on my Y axis - very very cheap, and very little if any backlash.
http://www.mycncuk.com/forums/showth...ll=1#post16365
(post #7)
What's needed for a 3d printer build??
By Davek0974 in forum 3D Printing MachinesReplies: 26Last Post: 18-02-2014, 11:54 AM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM -
RFQ: Help needed to build my first machine NE Norfolk
By Dorg in forum Projects, Jobs & RequestsReplies: 3Last Post: 31-10-2012, 09:30 AM -
new mashine build advice needed
By Finrod in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-10-2008, 11:05 PM
