    You draw your part in CAD then create a Gcode file using a CAM program
    The attached pic is drawn in the lower R/H corner this is X Plus Y Minus
    The piece is 100 mm square and you want to put a 20mm hole in the centre
    This assume your machine is perfectly set up, no backlash etc
    You only have simple equipment no edge finders of any type
    You will hold this in a vice clamped to the table with the back edge running perfectly parallel to the X axis
    Have the part stick out say 10mm on the left hand side
    You can use a dowel of 6mm dia or a cutter mounted in your collet upside down
    Bring the dowel up on the left hand side so it is just touching you can use a feeler gauge to do this but you have to add the feeler gauge thickness to the DRO's setting
    Once you have TOUCHED OFF set the DRO to the correct dimension then raise the Z and move the table to Zero it should be obvious if the dowel looks correctly on the centreline
    Then you repeat for the other axis
    Using this method you should be able to be accurate to 0.02mm
    You could also have other holes, recesses shapes in the plate but the edge finding is the same
    HTH
    Phil
Name:	Edge Finding.jpg
  2. The Following User Says Thank You to M250cnc For This Useful Post:
  3. #2
    i2i's Avatar
    I get a piece of paper and hold it between the cutter and the job, then gently move the cutter to the job until the paper is just trapped. You can do this on the edge of the cutter and the face, for x,y, and z.
    Quote Originally Posted by i2i View Post
    Yes i used to use a cigarette paper .001" with the spindle running, the trouble is that is very dangerous and i didn't want anyone to think i was in Jonathan & Blackburn Marks gang. :rofl:
    So this is a non dangerous way of doing the same.:lol:
    Phil
  5. #4
    i2i's Avatar
    Quote Originally Posted by M250cnc View Post
    Phil
    obviously without the spindle running.:lol:
  6. #5
    I do that too, adding 0.1mm for the thickness of the paper. Or get the cutter close, put the spindle on and move it so that you just hear it brushing.
  7. #6
    your all pussies !!!! i use one of my eye lashes.... while its still attached to my face :)
  8. #7
    True but we are not missing any bodily parts.
    Phil
  9. #8
    i2i's Avatar
    i used to wet a piece of paper and nudge the tool onto it but sometimes you get a fine witness mark on the job if you're a bit heavy handed. With a dry piece of paper and the spindle off you can feel the connection.
  10. #9
    i2i's Avatar
    and we can still see, those bionic eyes aren't all they're cracked up to be.
  11. #10
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Edge finders aren't that expensive - http://www.arceurotrade.co.uk/Catalo...t/Edge-Finders
    However, I've always used an edge finder, then if I need critical height, a bit wet paper, or just wind down/up until the tool just starts to mark the workpiece, depending on what I'm doing.
  1. The new probe and finding the center of a hole
    By Ricardoco in forum Probing, Digitizing & Scaning
    Last Post: 13-11-2015, 06:43 AM
  2. NEW MEMBER: Hello Matt & John here. Excited CNC Newbies
    By matt83 in forum New Member Introductions
    Last Post: 18-10-2012, 07:42 PM
  3. Finding pictures and viewing the albums of a member ?
    By WandrinAndy in forum General Discussion
    Last Post: 16-10-2012, 03:29 PM
  4. Finding Cheap Sign Foam Alternatives
    By action-kat in forum General Discussion
    Last Post: 17-08-2011, 08:45 PM
  5. Help with mach3 center finding script
    By eddie60 in forum Programmers Corner
    Last Post: 20-05-2009, 06:23 PM
