    Traditional tool makers used a sticky pin. This is a dressmaking pin held in a bit of plastacine (blue tac or chewing gum works but not as good) put on the cutter or drill. With spindle running, you press on side of tip of pin till it runs true. This could be done with a lolly stick or something like. You now have a fine point that is true with centre of cutter and can be lined up with edges, scribed lines and centre dots/pops.
    A wobbler set is a sophisticated version but although I use a set on lathes and mill I have always found a "Sticky Pin" most useful and quick. Wobblers are useful for edge finding but you do need height.
  2. The Following User Says Thank You to Phil Gravett For This Useful Post:
  3. #2
    fanatic idea thanks for sharing :)
    Quote Originally Posted by Phil Gravett View Post
  1. The new probe and finding the center of a hole
    By Ricardoco in forum Probing, Digitizing & Scaning
    Last Post: 13-11-2015, 06:43 AM
  2. NEW MEMBER: Hello Matt & John here. Excited CNC Newbies
    By matt83 in forum New Member Introductions
    Last Post: 18-10-2012, 07:42 PM
  3. Finding pictures and viewing the albums of a member ?
    By WandrinAndy in forum General Discussion
    Last Post: 16-10-2012, 03:29 PM
  4. Finding Cheap Sign Foam Alternatives
    By action-kat in forum General Discussion
    Last Post: 17-08-2011, 08:45 PM
  5. Help with mach3 center finding script
    By eddie60 in forum Programmers Corner
    Last Post: 20-05-2009, 06:23 PM
