Thread: Some Gcode generating programs
10-01-2011 #1
I've written a few little (and one not so little) programs to generate Gcode for some common tasks. I'll post them here gradually...
'Mad Professor' requested I make this one about half an hour ago - so here it is:
CNC HOLES GRID2.zip
It cuts a grid of holes within specified spacings and limits. Now outputs "hole grid.nc" in the same folder as you run the program from.
Please note I don't tend to bother with error checking! Put sensible numbers in and you should be fine.
[B]Let me know if there's any little program like this you want me to write.Last edited by Jonathan; 11-01-2011 at 01:13 PM.
11-01-2011 #2
Just tried running your hole program and it failed to start saying salflibc.dll could not be found.
Mike
11-01-2011 #3
Ahh, thanks for letting me know. Here it is:
salflibc.zip
Unzip and copy it to the same folder as the program or your windows/system32 folder if that doesn't work.
11-01-2011 #4
Hi Jonathan,
Thanks for that - that did the trick.
Cheers,
Mike
11-01-2011 #5
Looks like a very handy and quick program to use.
But could you also please add, Plunge Rate, and Spindle speed.
Best Regards."If first you don't succeed, redefine success"
11-01-2011 #6
For those Mach3 users not aware Mach3 does have a hell of a lot of wizards built in.
Jonathan not dissing your efforts maybe you would be better writing wizards that are not available built in, no need to waste time reinventing the wheel.
Phil
11-01-2011 #7
The feed rate it prompts for applies to plunging. I'll add the spindle stuff in a few minutes.
I didn't realise that there was a similar wizard in Mach3 until after I'd written this program!
Originally Posted by M250cnc
Can you think of anything that's not already in Mach3 that you would like?
11-01-2011 #8
14-01-2011 #9
Well here's something that's not in the Mach3 wizards...indeed someone charges for a very similar program.
4 axis Gcode generator for XL timing pulleys. Mills the trapezoidal tooth profile using small endmill. A axis is used to rotate pulley allowing the 25 degree angles to be milled for the precise tool profile. Needs 1.3mm or less endmill for XL...I've got a 1mm.
PULLEY GCODE.zip
Consider this an alpha release. I see no reason for it not to work, the gcode looks fine in mach 3 (be sure to set the A rotations display and the A offset to the radius of your pulley) however I have not tried it on my milling machine yet! Again, no error checking yet!!
I've coded it so that all the dimensions are calculated from the few dimensions that define the trapezium (lots of trigonometry & scribbling)- so I can easily add other pulleys such as metric T series aswell as L, MXL etc...if anyone's interested.
(I know a form tool would be a quiker way of making these, but that's difficult to grind.)Last edited by Jonathan; 15-01-2011 at 12:37 AM.
15-01-2011 #10
Hi Jonathan,
Have you looked at Gearotic, a program being developed by Art (founder of Mach). He uses similar methods for cutting spur, helical and bevel gears and includes some pulleys too. Take a look http://gearotic.com/, it's a work of art - pun intentional :) There's also an excellent forum.
Mike
Apple mac pro, What are the best programs to use with a mac?
By alex wight in forum CAD & CAM SoftwareReplies: 14Last Post: 07-02-2014, 12:56 PM -
WANTED: Van ply lining programs
By vehicle accessories in forum Items WantedReplies: 0Last Post: 31-08-2013, 12:34 PM -
Examples Heidenhain programs with drawings
By hoezap in forum Computer SoftwareReplies: 0Last Post: 09-02-2013, 12:54 AM -
Tapping Gcode
By Kai in forum General DiscussionReplies: 10Last Post: 14-12-2010, 07:07 PM -
Software for generating toolpaths
By alan2525 in forum Computer SoftwareReplies: 4Last Post: 07-04-2010, 09:33 PM
