Thread: Some Gcode generating programs
15-01-2011 #11
02-05-2011 #12
Hi Jonathan,
One change or add on that I am keen to get for mach 3 is the ability to centre text. The current wizard has all kinds of fonts and settings which is great but lacks the ability to centre/resize text to a given size box.
I want to use Mach 3 for more engraving and this is holding me back. Would this be possible?
Dan
02-06-2011 #13
hi jonathan.... with regards to your XL pully g-code gen :) i was wondering if you could mod it (you gave the impression you could change it whilst eating a kebab n watching telly :)
iv ground an engraving tool to cut my tooth shape (sincroflex 2.5) and thats cutting well enough to give it a whirl
its a 2.5mm pitch with 0.7mm deapth.... im looking to plunge in to my pully from the top takeing two cuts per slot
i know your a busy dude so no problems if you cant fit it in
mark xxx
02-06-2011 #14
02-06-2011 #15
Here it is (written in the car on the way back from grandparents, had to wait til now to get internet)... send me the Gcode if you want before running it and I'll check its not done anything too silly. Should be ok though...
PulleyCalc4.zip
I've included an example Gcode file with the numbers you gave. Let me know how it goes.
The Following User Says Thank You to Jonathan For This Useful Post:
04-06-2011 #16Smart arse !!!!!written in the car on the way back from grandparents
nice one jonathan :) ill give it a go and report back as soon as i get the chance :)
04-06-2011 #17
I couldn't look it up at the time, so left it so you could enter the distance between the pitch diameter and pulley surface. For T5 you want to enter 0.5mm.
(Source: http://www.sdp-si.com/D265/HTML/D265T016.html )Last edited by Jonathan; 04-06-2011 at 10:57 PM. Reason: It was wrong.
10-06-2011 #18
YeeeeeHaaaaw !!!!
thats a winner jonathan
i guess you have your 4th parrallel to your X axis
i have to edit the g-code for Y axis but its still saving me a shit load of effort :)
cheers man xxxx
10-06-2011 #19
Yes I set it up for an A axis not B. I think the easiest way for you to change it is just swap the X and Y pins on the parallel port in mach3. Then your B axis magically becomes an A! I'll look if I can easily get the program to swap.
Glad to hear it's working otherwise. Any pictures?
10-06-2011 #20
ill try to get some video up of the next one i cut :)
Apple mac pro, What are the best programs to use with a mac?
By alex wight in forum CAD & CAM SoftwareReplies: 14Last Post: 07-02-2014, 12:56 PM -
WANTED: Van ply lining programs
By vehicle accessories in forum Items WantedReplies: 0Last Post: 31-08-2013, 12:34 PM -
Examples Heidenhain programs with drawings
By hoezap in forum Computer SoftwareReplies: 0Last Post: 09-02-2013, 12:54 AM -
Tapping Gcode
By Kai in forum General DiscussionReplies: 10Last Post: 14-12-2010, 07:07 PM -
Software for generating toolpaths
By alan2525 in forum Computer SoftwareReplies: 4Last Post: 07-04-2010, 09:33 PM
