    I didn't realise that there was a similar wizard in Mach3 until after I'd written this program!
    Can you think of anything that's not already in Mach3 that you would like?
    Not me personally I don't use the wizards but thanks for the offer.
    If your at a loose end look on the Mach3 forum for any that are wanted, if you can do you will become very popular.
    Phil
    Sent from my HTC Desire using Tapatalk
    Well here's something that's not in the Mach3 wizards...indeed someone charges for a very similar program.
    4 axis Gcode generator for XL timing pulleys. Mills the trapezoidal tooth profile using small endmill. A axis is used to rotate pulley allowing the 25 degree angles to be milled for the precise tool profile. Needs 1.3mm or less endmill for XL...I've got a 1mm.
    PULLEY GCODE.zip
    Consider this an alpha release. I see no reason for it not to work, the gcode looks fine in mach 3 (be sure to set the A rotations display and the A offset to the radius of your pulley) however I have not tried it on my milling machine yet! Again, no error checking yet!!
    I've coded it so that all the dimensions are calculated from the few dimensions that define the trapezium (lots of trigonometry & scribbling)- so I can easily add other pulleys such as metric T series aswell as L, MXL etc...if anyone's interested.
    (I know a form tool would be a quiker way of making these, but that's difficult to grind.)
  1. Apple mac pro, What are the best programs to use with a mac?
    By alex wight in forum CAD & CAM Software
    Last Post: 07-02-2014, 12:56 PM
  2. WANTED: Van ply lining programs
    By vehicle accessories in forum Items Wanted
    Last Post: 31-08-2013, 12:34 PM
  3. Examples Heidenhain programs with drawings
    By hoezap in forum Computer Software
    Last Post: 09-02-2013, 12:54 AM
  4. Tapping Gcode
    Last Post: 14-12-2010, 07:07 PM
  5. Software for generating toolpaths
    By alan2525 in forum Computer Software
    Last Post: 07-04-2010, 09:33 PM
