    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    My cross slide has over 10thou of backlash just now, but it doesn't cause me many problems. You've just got to compensate for backlash, and realise what you can and can't do.
    Looking at the diagram you've got, it looks as though you're planning on controlling endfloat by using a bearing at each end, and then preloading the entire ball screw. If you are, it's not a good way to do it, as due to expansion/contraction of the various components, things can get deformed.
    You should control endfloat by having one end of the ballscrew fixed (ie. a couple double angular contact bearings to set endfloat) and the other floating (ie. either a bearing that supports the screw but allows it to slide through it, or a sliding coupling if you're using the stepper motor to support the shaft).
  2. Quote Originally Posted by m_c View Post
    My cross-slide has >1mm of end-float and about 0.5mm of backlash, basically the threads are shot! Its usable, just, as long as you keep pressure on it... but then it is 85y old!
    Re the thrust arrangement, yes I know thats the right way, but its also the expensive way and I did look for a cheap tapered roller bearing as an option but there weren't any to be found and I was looking for a cheap and easy solution that would work for me most of the time. :) I was working on the assumption that the leadscrew will experience the same temperature variation as the linear rails, which ARE locked solidly at both ends, so while there may be some distortion it cant be any worse than they would experience. Another way to look at it is the leadscrew has a coefficient of 13um per metre per deg C, so for a 400mm screw it will change length 13 * .4 * 10uM or 0.052mm for a 10 degC variation (which is what I would expect in its current location). I'll be happy if the endfloat is less than 0.1mm!
  3. Revised arrangement using back to back skate bearings and thrust nut at far end and sliding bearing at stepper end...
Name:	thrust ferrules2.jpg
  4. The previous arrangement put an axial load on the skate bearings which they don't like and as a result the friction is much higher than I liked. Part 4 in the diagram is a acetal thrust bearing from BNL, supplied by RS at £0.73p which addresses the issue.
    The only critical dimension is the thrust washer, part 5. The ID of this part must be large enough not to foul the shaft and the OD large enough to butt to the bearing black and not slip inside to foul the skate bearing whch is recessed 0.5 - 1mm to stop this happening.
    A belleville washer could save you hours of fiddling about setting that up, but just how do you plan to drill through the screw and where have the bleedin' smilies gone when I need them?
  6. what do you mean "drill through the screw"?:confused:
    and the smilies are here...
    "The ferrules are retained on the leadscrew by a 4mm hole drilled through the ferrule and the screw".
    There used to be a handy panel of smilies next to this here reply box, now it's gorn
  1. ACME / Trapezoidal leadscrews
    By ZeroCount in forum Lead Screws, Nuts & Supports
    Last Post: 08-03-2020, 09:29 AM
  2. Fitting a pot to a Chinese Spindle VFD
    By Clive S in forum Spindles & Drive Motors
    Last Post: 14-07-2018, 12:51 PM
  3. Belt Driving your leadscrews !
    By Lee Roberts in forum Lead Screws, Nuts & Supports
    Last Post: 05-02-2011, 09:14 AM
  4. Motors and leadscrews
    By Tom in forum Gantry/Router Machines & Building
    Last Post: 29-05-2009, 10:37 PM
  5. Fitting new screws
    By Robin Hewitt in forum General Discussion
    Last Post: 15-02-2009, 09:34 PM
