Thread: Stepper Motor Wire Colour Codes
24-01-2011 #2
I was but aparently there is no standard colour code for the wires got the nema 23 size ones infront of me and they have 6 wires
these are BL,G,R,B conected to the board A+,A-,B+,B- white and yellow not used at all
I can follow a wireing diagram but as to the indeph tecnical stuff with electirkery I am a bit fooked
Jonathan gave me the ides to turn the power down on the controler board which has worked
they have been running the roadrunner for 2 hours and only luke warm now
as for bipolar ECT just dont know as the wireing crapagram dont actualy say which is which
Any help M8 ?
24-01-2011 #3
[2 posts for the price of one]
24-01-2011 #4
The way you have it connected is probably the best. The other way would be what's called 'half coil' which, as the name suggests, only uses two out of the 4 coils in the motor. You'd then use the center white/yellow wires and BL / R. That, I think, would get the motors going faster - but with much less torque since the magnetic field is smaller due to using less coils. If I recall correctly the manual for the stepper drivers I use explains it:
http://www.slidesandballscrews.com/p...ml?cPath=44_97
If not google is your friend.
Before you were using 3.5 amps, now 3 amps so since power lost is I^2*R, that's 3^2/3.5^2 = 73% of the heat you had before.
Stepper wiring/colour coding
By rwb97 in forum Stepper & Servo MotorsReplies: 24Last Post: 23-06-2014, 11:34 AM -
VFD to motor cable wire size (Gauge)
By artman12us in forum Spindles & Drive MotorsReplies: 2Last Post: 24-04-2014, 07:11 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM -
Motor controllers/drivers/wire ?!?
By Lee Roberts in forum Motor Drivers & ControllersReplies: 8Last Post: 24-08-2007, 08:46 PM
