    dont let that intimidate you jonathan, in this country it could easy mean spending 15 years with a cup o tea in one hand and a fag in the other and wondering which hand to scratch your arse
    Probably true in your case Mark
    Phil
    Sent from my HTC Desire using Tapatalk
    Quote Originally Posted by M250cnc View Post
    :rofl:
    I haven't found sub 3mm tooling in high helix with a rebate on the flutes and the carbide tinies tend to be coated with other than aluminium nitride so that helps not a lot.
    That sentence took me a bit of time to decipher!
    Even so, I wouldn't step drill it. Presumably you've turned a blank for the pulley and removed any surface hardening from the extrusion, if it isn't cast, and there is no oxide layer to wear an inconvenient slot in the flutes. Personally I'd go for around 2000 rpm, feed it at 1 -> 1.5 mm/s on a 3 flute, start with .25mm DOC, increasing if it seems good to go.
    Yes I'm using aluminum bar, not cast. I wasn't aware of surface hardening being an issue with aluminum (iron yes), however now you mention it it makes sense. One anodises aluminum to make the surface harder (or prettier), so it follows logically that the natural layer of aluminum oxide will wear the tool.
    42T pulley with 0.25mm DOC and 1.5mm/s will take 170 mins. Maybe a little less if I get rid of some rapids in Gcode, but not much.
    Chip thinning may enable me to run the cutter a bit faster for the same chipload a significant amount of the time. I can quite easily add that to my program.
    I'm warming to the make a tailstock (anyone got a spare!) and just use slitting saw idea. I can stop the 63mm slitting saw bending by machining some 50mm steel disks and sandwiching it between those on the arbor.
    Standing over it with a blow gun, a pot of Rocol RTD and a brush could be an exceptionally good idea even if this temporarily suspends tea, fags and scratching
    Who says I can't drink tea whilst doing that!
    At risk of sounding patronising, I suppose it would be sociable on an open forum to explain that there is a difference when it comes to aluminium :naughty:
    I've just taken a picture, two 3mm cutters designed for aluminium, one ordinary, 1mm, 3 flute carbide slot drill
  1. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  2. Do such endmills exist?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 04-04-2013, 11:52 PM
  3. FOR SALE: Dormer S259 Endmills for sale, 12mm 10mm 8mm 6mm solid carbide
    By davy in forum Items For Sale
    Last Post: 10-11-2012, 05:55 PM
  4. cutter chipload
    By johngoodrich in forum Tool & Tooling Technology
    Last Post: 17-09-2011, 01:02 PM
  5. RFQ: Maybe another small(ish) job for someone...
    By D-man in forum Projects, Jobs & Requests
    Last Post: 05-07-2010, 11:47 AM
