Thread: Securing the workpiece
	16-06-2012 #1
Hi All,
I tend to cut Acrylic and some wood when I have the time. I currently use double sided tape which works well but is also messy.
I have an alloy bed on which I mounted a piece of wood (it's actually kitchen worktoo chipboard) which allows me to have the odd moment of "oops, glad I have that piece of wood there" rather than driving into the bed.
I do plan to remove the wood at some point once I get a pretty good routine in place so, would I look to use some kind of clamps through the bed? It has slots, possibly called "T" slots. If clamping is the best solution, is it just a case of making something to do the job, or are there some great off the shelf products? I'm not looking to spend much so cost is a factor but if there is something available then I'll have a peek.
James
	16-06-2012 #2
I think these are what your looking for which allow you to clamp work in all manner of arrangments.
http://www.rdgtools.co.uk/acatalog/M...ping_Kits.html
	16-06-2012 #3
Brilliant. Thank you so much for the link. Will see what I have around first.
Thanks again.
James
	16-06-2012 #4
You can also use bolts with a head thats bigger than the t slot and just grind to side oposite to each other equal until they slide in.
Workpiece illumination
By cropwell in forum Workshop & EquipmentReplies: 0Last Post: 29-09-2013, 10:21 PM -
Securing and Aligning Ballnuts
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 29-09-2012, 11:39 PM -
Workpiece hold down by glue
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 30-09-2010, 08:22 PM -
Securing your network !
By Lee Roberts in forum Computer SoftwareReplies: 0Last Post: 19-11-2008, 01:18 AM
